What Is the pH of 0.15 M Methylammonium Bromide Solution?
  • Thread starter Thread starter mnnob07
    Ph
The pH of a 0.15 M methylammonium bromide (CH3NH3Br) solution is calculated to be 0.83, due to the complete dissociation of the strong acid HBr, which forms from the salt. The equilibrium reaction CH3NH3+ + H2O <=> CH3NH2 + H3O+ is used to derive the pH, with the equilibrium constant Ka calculated as 2.27 x 10^-11. The confusion arises from the dissociation process, where CH3NH3Br separates into CH3NH3+ and Br-, with Br- acting as a spectator ion. The final pH reflects the strong acidic nature of HBr rather than the weak base characteristics of CH3NH2.
  • Understanding of acid-base chemistry, particularly weak acids and strong acids.
  • Familiarity with the concept of ionic compounds and their dissociation in solution.
  • Knowledge of equilibrium constants and their calculations, specifically Ka and Kb.
  • Ability to perform logarithmic calculations for pH determination.
  • Study the dissociation of ionic compounds in aqueous solutions, focusing on salts like CH3NH3Br.
  • Learn about the relationship between pKa, pKb, and pKw in acid-base chemistry.
  • Explore the concept of conjugate acid-base pairs and their role in equilibrium reactions.
  • Investigate the properties and behavior of strong acids versus weak bases in solution.
Chemistry students, educators, and professionals involved in acid-base chemistry, particularly those studying ionic compounds and their dissociation in solutions.
mnnob07
What is the pH of .15 M methylammonium bromide, CH3NH3Br (Kb of CH3NH2 = 4.4x10^-4)
I actually asked this to someone else and got this:
CH3NH3 (aq) + H2O (l) <=> CH3NH2 (aq) + H3O+ (aq)
Kw = KaKb
Ka = (10-14)/(4.4 x 10-4) = 2.27 x 10-11
ICE chart:
I .15 M 0 0
C -x +x +x
E .15-x x x
Ka = (x^2)/(.15 - x) = 2.27 * 10^-11
x = 1.85 x 10-6 M = [H+]
pH = -log([H+]) = -log(1.85 x 10-6) = 5.73
It just doesn't seem right. To use the information given for CH3NH2 we need to first have CH3NH3 or CH3NH2 in the solution but we start with CH3NH3Br. Where did the bromine go? first off here is CH3NH3:
http://img59.imageshack.us/img59/571/chemistryfecee368c664afax2.jpg
I'm not very far in chemistry and maybe that's why I'm confused, but CH3NH3 simply could not have had bromine tacked on somewhere on the above model ready to fall off.
There's simply no room; H, C, and N have their orbitals filled in CH3NH3
It would seem (and I can't find a reference for this so I'm likely wrong) that CH3NH3Br looks like this:
http://img57.imageshack.us/img57/5500/chemistrye6393df93de99fmq2.jpg
It would dissociate as follows:
CH3NH3Br -> CH3NH2 + HBr
now, that CH3NH2 would follow the reaction originally stated with the associated equilibrium constant that was given, but the OH- created from that will pale in comparison to the H30+ generated by the strong acid HBR:
HBr + H20 -> H30+ + Br-
since it is a strong acid, it will dissociate completely and we will be left with [H30+] = .15M
pH = -log[H30+]
pH = -log(.15)
pH = .83
I would appreciate any help, I just want this whole thing to chemically make sense to me. BTW, we haven't covered buffers yet so that shouldn't be a huge part of the solution
OK I'm not sure how to post images. just click on the images below for the basic structures (sorry I didn't explicitly label the lone pairs around Bromine but there should be 3 I think)
When dissolved methylammonium bromide dissociates to CH3NH2+ and Br-.
Such a compound is commonly called hydrobromide - what it means is that you have an ionic salt consisting of protonated amine and Br-. Thus to calculate pH you have to assume you really have a solution of CH3NH2+ - which is your acid.
am I able to use the same equilibrium constant for CH3NH2+ as I do with CH3NH2? The question doesn't give any information about CH3NH2+ and I don't see it in the book's appendix
Also, if CH3NH3Br -> CH3NH2+ and Br-
what happened to the other H? and is that dissociation complete or at equilibrium?
These are pair of conjugated acid and its base, pKa + pKb = pKw.
Complete dissociation. You have lost H - no idea why. It is not CH3NH2+ but CH3NH3+.
Edit: sorry, my typo in previous post. Should be CH3NH3+.
ok so we have:
CH3NH3Br -> CH3NH3+ and Br-
Br- is a spectator ion and is no longer needed
CH3NH3+ and H20 <-> CH3NH2 and H30+
Ka = Kw/Kb(of reverse which was given)
Ka = 1.0*10^-14 / 4.4*10^-4
and so on. That's exactly what I had in my first post. I later stated what I don't understand about it and my question but I stand with no better understanding than before. It's possible you just didn't read my whole post and I can't be mad at you for trying to help, in fact I am very pleased you tried to help and confident your method is correct but just knowing CH3NH3Br dissociates that way does little to help me in the long run.
My question was, how does that work? like, chemically and structurally. WHERE DOES THE BROMINE COME FROM? It is possible I do not have as complete understanding with ionic bonding and maybe some other ways the atoms bond as I should, but if CH3NH3 looks like this:
http://www.meta-synthesis.com/webbook/40_polyatomics/sp3_sp3.jpg
CH3NH3+ must have a missing electron and somewhere that bromine could attach to (I'm sorry if this is a crude way of explaining this but I am trying) the problem is that there is NO WHERE for the bromine to have been bonded to; it certainly was not attached to hydrogen and there's no room on Nitrogen and Carbon so it couldn't have been attached there (those two don't even have d orbitals (expanded octet) although maybe that's only a consideration in covalent bonding?)
something-NH2 behaves just like NH3 - it gets protonated and that's where the additional charge comes from. H+ goes into the lone electron pair. As you have correctly stated, bromine is just a spectator. Technically ammonia or amine protonation is very similar to water protonation, just ammonia is central atom plus three H plus one lone pair, while water is a central atom plus two H plus two lone pairs.
So something-NH2 gets protonated to something-NH3+
how does the bromine attach to something-NH3+?
It is not bromine, but Br-, I told you it is an ionic compound. Just like NaBr, or - more closely - NH4Br.
alright, I saw in a couple places that CH3NH3Br and CH3NH3Br were salts of CH3NH2 and HBr/HCl but they were probably just wrong. the ionic bonding makes sense, thanks.
But they are salts of these. Just nitrogen gets protonated, that's where the cation comes from. HBr dissociates (it is strong acid), proton protonates nitrogen, Br- is left as counterion
step-by-step:
CH3NH3Br is a salt and dissociates as:
CH3NH2 protonates:
CH3NH2 and H20 <-> CH3NH3+ and OH-
but there's also:
HBr -> H+ and Br-
now, while CH3NH2 protonates to give us the CH3NH3+, the Kb given for that seems to suggest it's not going to be much of a factor with as much as the strong acid, HBr from the salt dissociates. That is the step that leads me to believe the pH is actually much lower than simply looking at CH3NH3+ because there is a step between CH3NH3Br dissociating until we get to the CH3NH3+. We haven't gotten to buffers yet, though...
No...
You start with CH3NH2. Nothing dissociated yet (although it is a weak base, so it already reacts to some extent with water producing OH-, we will leave it for now).
You have separate solution of HBr - fully dissociated into H+ and Br-.
You mix both solutions.
CH3NH2 reacts with H+:
CH3NH2 + H+ = CH3NH3+
Now you have solution containing CH3NH3+ cation and Br- anion. When dried, it will give ionic solid. When dissolved, it will give the same solution of two ions.
Sorry, I have no idea how to explain it further or more clear, if you still don't understand, perhaps someone else will be able to help.
Start over a bit. This is mostly simple acid-base chemistry.
You may be a bit familiar with ammonia, NH3. A strong acid can
neutralize this to give the ammonium cation, NH4+.
NH3 + HCl ------------> NH4+ + Cl-
Instead of ammonia, a nitrogen-base can be an amine such as
methylamine, CH3NH2. A strong acid can neutralize this to give
the methylammonium cation, CH3NH3+. (All hydrogen halides are
strong acids, except for HF).
CH3NH2 + HBr ----------> CH3NH3+ + Br-
When you consider each salt by itself, without any added strong acid,
there is NH4Cl for the first situation, and there is CH3NH3Br for the
second situation.
Chlorides and bromides are completely ionic, and generally very soluble
in water.
EACH OF THE COMPOUNDS IS A WEAK ACID.
Just as ammonium dissociates to NH3 and H+,
methylammonium dissociates to CH3NH2 and H+
This is the third time I'm trying to post and physicsforums keeps saying that some security token is missing and I lose the post.
I think I get it
CH3NH3Br -> CH3NH2 and H30+ and Br-
now, I'm going to just reverse the next step I had in my last post and it makes this much more clear:
CH3NH3+ and H20 <-> CH3NH2 + H30+
because there is SO MUCH H30+ and CH3NH2 from the CH3NH3Br this equilibrium is VERY lopsided. by Le Chatlier, the reaction will shift heavily to the left, effectively eating up most of those H30+ from the HBr. the rest of the problem follows as normal. That might be all I was missing.
mnnob07, You seem now to understand most of the quality and reaction. What is not too clear is your description of "lopsided...". Anyway, you have apparently made important progress.
right; first I was confused why I kept on being told that CH3NH3Br went right to CH3NH3+ and Br- now I see how it gets there.
I meant lopsided by the fact that in the second step, (that is, between the newly formed CH3NH2 and H30+ and the resulting CH3NH3+) there were 0.0M CH3NH3+ and .15M CH3NH2 and H30+... lopsided may not have been the best word choice... oh well
In any case, that is how CH3NH2 and H30+ went to CH3NH3+ so strongly which I think is really what Borek was trying to say while I was still thinking there was a lot of H30+ leftover from the HBr. Now, I think I got this down let me know if there's anything I'm still missing...
mathematically:
Ka = Kw/Kb(of CH3NH2) = (1.0*10^-14)/(4.4*10^-4) = 2.3*10^-11
Ka = ([CH3NH2][H30+])/[CH3NH3+]
___CH3NH3+___CH3NH2___H30+
I_____0_________.15______.15
C____+x_________-x_______-x
E_____x________.15-x____.15-x(2.3*10^-11) = ([.15 - x][.15 - x])/[x]
x = .149998142594 ~ .15 = [CH3NH3+]
Thus, Borek correctly assumed that above reaction virtually went to completion so he went right to CH3NH3+ and calculated H30+. Now, there are several correct ways of doing this and the above is the same equilibrium and if you temporarily ignore sig figs you get the same answer -log[H30+] = -log(.15 - x) = -log(.15 - .149998142594) = 5.73. Of course, with respect to sig figs, Borek's method would be more sound and succinct probably from a chemist's point of view.
Thanks Borek and symbolipoint!
I have not presented any method yet, I was referring to qualitative description so far. You are right, protonation reaction is shifted (almost) completely to the right.
  • · Replies 22 ·
11K
