Calculating pH After Adding NaOH to NaC3H5O2 Solution
  • Thread starter Thread starter Doodan
    Ph
The discussion focuses on calculating the pH of a 0.1 M sodium benzoate (NaC3H5O2) solution after the addition of 0.02 moles of sodium hydroxide (NaOH). Participants emphasize the use of the Henderson-Hasselbalch equation to determine the resulting pH. The interaction highlights the need to understand the equilibrium between the weak acid (benzoic acid) and its conjugate base (sodium benzoate) in the solution after NaOH is introduced.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of weak acid and conjugate base equilibria
  • Familiarity with molarity and solution preparation
  • Basic concepts of acid-base reactions
  • Study the Henderson-Hasselbalch equation in detail
  • Learn about the equilibrium constants for weak acids and their conjugate bases
  • Explore the effects of strong bases on weak acid solutions
  • Practice calculating pH changes in buffer solutions
Chemistry students, educators, and anyone involved in acid-base chemistry or buffer solution calculations will benefit from this discussion.
Doodan
This question refers to a previous question in my book: Calculate the pH of .1 M NaC3H5O2. The question I'm stuck with now: Calculate the pH after .02 mol NaOH is added to 1 L of the *previous* solution.
The Henderson-Hasselbalch equation or the simple equilibrium equation has to be used here.
I don't know where to start actually...please help :)
Write out the Henderson Hasselbach equation and tell us which terms you don't understand. Write out the equation for the combination of the two reagents and tell us what you don't understand.
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 23 ·
