Fra
- 4,460
- 745
Fra said:A binary stream is the simplest case. But depending on the contents of the data stream, a binary stream may self-organise into, say a hex stream, if it's the most efficient representation. But this is just one possible mechanism out of many.
One of the basic ideas is that each possible data set, has it's own preferred optimum representation in it's relative context. So when I said "binary stream is the simplest case" isn't really true! beucase sometimes, depending on the data some other representation may be more efficient, and thus are _most likely_ to be chosen, given that we really don't know. So there seems to be no universal answer to what simple is, and subsequently not what "optimum configuration is", which is exactly what should lead to dynamics. The duality between large and small, and simple and complex, leads to changing relations - dynamics, which by definition defines new relations, ongoingly.
In short, my starting point is some kind of abstract data stream... no space or geometry is even thought of at this point. It's assume that there is some kind of "processing device", which really is thought to simply be a self organising memory - the self organisation the "processing". I consider that ultimately such a thing can evolve from the starting point of a single bit. The exact rules, is what I'm working on. Eventually the concept of dimension and geometry will be organized, the reason for this appearing is simply that it's more likely than the opposite. The actual outcome, and actual dimensions will reside in the data itself. This is nothing we should put in by hand, it should ideally not be needed.
I can see several possible formalisms to attack this. But my motivation is not in the standards of formalisms. By the same token above, I think that perhaps the optimum formalism depends on the point of view, because the descroption of the formalism itself occupies memory and processing power. Like in datacompression, the highly efficient compression algorithsm often take longer time to decode. So the concept "optimum" is not that obvious after all. I think it's relative to context. Which is one of the founding ideas. This it bothers me to be forced to make a seemingly arbitrary choice.
/Fredrik
