Photo Contest - The Elements (2/20-2/26)
9 replies · 2K views · last reply
Staff Emeritus
Homework Helper
Insights Author
The Elements
For this contest, your photo must have, as its main subject, something that is made up of, or popularly identified with, a single element.
For example, your gold jewelry, even though it may contain a small amount of other elements, is identified usually as a single element of gold, i.e. Au. A lot of cookware are made of aluminum (with added impurities), and so it can be identified as the element aluminum, or Al.
However, you can't use things such as the regular table salt, since it has equal portions of Na and Cl, and it is a compound, not an element. The same with water since H2O is a compound.
Good luck!
Zz.
Contest Rules:
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Ferrous Wheel
Close-up photo of heavily rusted iron machinery with orange-brown corroded surfaces and several dome-shaped bolt heads or rivets.
  • Close-up photo of heavily rusted iron machinery, with orange-brown corrosion covering domed rivet heads and curved metal plates.
Looks more like ferrous oxide to me. :oldwink:
Single-crystal silicon. This particular piece is a ten-nines wafer or 99.99999999% pure
Photo of a circular silicon wafer lying on a lined notebook, reflecting a bright light source and a blurred window-like pattern, with a spiral notebook binding at upper left.
Rh (+C)
Silver mechanical pencil lying on lined paper covered in handwritten equations, with a white eraser beside it that has a dark pattern on its top.
Rh and C
Do I get points for rarity? The visible element that plates this object is rhodium. You can also see elemental carbon in the picture.
The object, for those who like me had forgotten them, is a pencil. It was on PF that I learned that proper mathematicians use them. This allows them to keep their pages neat and legible by rubbing out their mistakes, instead of the messy confusing pages I always ended up with. So in order to do advanced mathematics I obviously needed to acquire a pencil. Experience proved that the complement of a rubber, also illustrated, was indeed useful, almost necessary.
The cheap wooden pencils they sell to kids and students were obviously inadequate for the advanced mathematics of my ambitions. So I invested in more advanced technology, incorporating discoveries of Wollaston, Faraday and others. Anyway I have always been fascinated, for some reason, by rhodium, despite or maybe because of the paucity of its chemistry. And now I am not happy and feel held back doing maths with any other pencil. This technology has enabled my pathbreaking work on equivalent capacitances, which you can glimpse in the photo (as well as some elemental carbon) which was meritorious enough to be published in the prestigious journal, PF Homework Help.
