Photobleaching of fluorophores
  • Context: Graduate
  • Thread starter Thread starter gkiverm
The discussion centers around the phenomenon of photobleaching in fluorophores, particularly the mechanisms that lead to their chemical degradation when continuously excited. Participants explore the underlying physics and chemistry concepts, including electron states and transitions, while seeking clarity on terminology and processes involved.
  • Some participants explain that photobleaching occurs due to photon-induced chemical damage and covalent modification, leading to the destruction of the fluorophore's ability to fluoresce.
  • One participant describes the process of fluorescence, detailing the transitions between singlet and triplet states of electrons and how these states relate to reactivity and potential chemical reactions.
  • Another participant distinguishes photobleaching from quenching, noting that quenching is a reversible process involving non-radiative energy transfer.
  • Questions are raised about the mechanisms of radiationless de-excitation and the conditions under which intersystem crossing occurs.
  • There is a discussion about the relationship between intersystem crossing and the formation of reactive oxygen species, with references to oxygen's triplet state and its reactivity.
  • Participants express varying levels of familiarity with the relevant physics and chemistry concepts, indicating a range of educational backgrounds.
Participants do not reach a consensus on the explanations for photobleaching and related processes. Multiple competing views and uncertainties remain regarding the mechanisms involved, particularly concerning radiationless transitions and the implications for chemical reactivity.
Some limitations include the complexity of terminology such as singlet and triplet states, and the varying levels of understanding among participants, which may affect the clarity of explanations provided.
This discussion may be of interest to individuals studying photochemistry, fluorescence microscopy, or those seeking to understand the chemical behavior of fluorophores in various applications.
gkiverm
Can someone explain the cause behind photobleaching (http://en.wikipedia.org/wiki/Photobleaching) of fluorophores when they are continuously excited. The wikipedia article does not really explain why photobleaching occurs.
I tried looking it up online, and most explanations were too complicated for my background in physics / chemistry. I got into terminology with words like singlet and triplet state.
Thanks!
It happens by photon-induced chemical damage and covalent modification. As I'm sure you might know, florescence is caused by the absorption of a photon, then the admittance of a florescent photon. Well, pretend we have two electrons in the ground state, one with a spin of [tex]+\frac{1}{2}[/tex] and the other with a spin of [tex]-\frac{1}{2}[/tex]. The sum of their spins is 0. We call this state this singlet state. Well, when one electron absorbs a photon and gets promoted to a higher energy level one of three things can happen. It can keep its spin, either the [tex]+\frac{1}{2}[/tex] or [tex]-\frac{1}{2}[/tex] and the sum of their spins still be zero. This is called the excited singlet state. From here the electron can fall down back into the ground state and admit a fluorescent photon. The electron can also fall back to ground state without radiating anything. The other option is for the promoted electron to undergo something called Intersystem Crossing. This is where the spin of the electron is flipped in the transition and it is now the same as the as the electron in the ground state, a forbidden transition. This is now known as the excited triplet state. This triplet state is when the sum of their spins adds to 1. In this state they are incredibly reactive which allows them potentially interfere with bonds in the material. The chances of Intersystem Crossing happening aren't high, some factors can allow it to happen more frequently, but the more something is excited the more chances it has for this transition to happen.
Thanks!
Basically, photobleaching means the fluorophore has been (chemically) destroyed and can no longer fluoresce. When the fluorophore is in the excited state, after absorbing light, it can more easily undergo chemical reactions: oxidation, decomposition, etc.
Photobleaching is different than quenching: a reduction in fluorescence due to the non-radiative transfer of energy from the excited fluorophore to some other molecule. Quenching is reversible.
Thanks for the reply. I have some few questions though,
1) how can the electron fall back to the ground state without radiating anything? If the explanation is too complicated I can just take this for granted.
2) Does intersystem crossing only occur if the electron falls back without radiating anything?
Edit: Also, how does this relate to the formation of oxygen atoms that are free radicals?
1) Well, when an electron emits and absorbs a photon all it is doing is absorbing and re-emitting energy again. For a "radiationless de-excitation" as they are called, meaning they don't radiate a photon, the energy is just transferred to something else. This is normally done through some transference of vibrational energy that disperses as heat.
2) Yes, in a way! Intersystems crossing is a two-directional process that describes the radiationless transitions between a singlet state to a triplet state, and from a triplet state to a singlet state.
O2 naturally in its ground state due to its electron configuration is in the triplet state. Oxygen is incredibly reactive with the other triplet states which can cause oxygen to be reduced to its singlet state, forming free radicals. What is your level of education in physics and chemistry? I have some reading for you on the subject if you would like, but I don't know what difficulty level to tailor it to.
I have only taken chemistry I and II at the college level (introductory classes) and for physics I have taken a course on waves, oscillations, and quantum physics (which is a little above the level of an introductory college course).
Introductory college course can be a little misleading. At my school there are 4 different "introductory" physics classes. There is physics for non-science majors (no math, all concepts), physics for life sciences (algebra based physics), physics for engineers (calculus based applications of physics), and then physics for majors (calculus based physics, application,and theory). If you are comfortable with calculus then this should give you some extra information.
http://www.wiley-vch.de/books/sample/3527316698_c01.pdf
  • · Replies 20 ·
