I Photon Entanglement: Identifying & Using an Entangled Pair
RobbyQ
In this video how are the entangled photons later used and actually identified as an entangled pair amongst billions of others.
Also does he really mean the photon is split or is the quantised energy split with half frequencies?
He is using a "Parametric Down Converter" (PDC). So if you send violet photons (400nm) into this PDC
and all goes well you get two deep red photons coming out. The violet photon "splits" into two red photons, each with half the energy.
The photon pairs that are entangled are most readily identified as the red ones coming from the device. So if you put a filter on the output that blocks all violet photons, all of the photons emitted from the device will be the entangled ones.
Likes vanhees71 and RobbyQ
Thanks. But how do you associate 2 entangled photons out of the whole bucket load of entangled photons. And how do they measure the shared quantum state of 2 entangled photons and put it to practical use once there is a state collapse from observation?
The pair of photons will be emitted at the same time. If you need to "associate" them, one way is to dim the light intensity down to slow the average rate that the photons are emitted. If the time between photon pairs is long enough (say about a nanosecond), then you are able to detect and count individual photons.
If demonstrating the Bell inequality is considered a "practical use", then direct each photon from the pair to a separate polarization detector. The entire set up is described here: Bell Inequality Test
Just to add to @.Scott ‘s correct answer: the pair is entangled if they are detected within a specific coincidence time window, let’s say 10 nanoseconds. Note that the timing is adjusted for the relative length each one travels. Commonly in normal situations, only one pair is seen in any time window regardless of laser intensity because only 1 in perhaps 10 million down converts.
In many PDC setups, the split photons veer off at a slight angle while the rest go straight ahead. That makes it possible to distinguish them as well.
The fidelity of the detected pairs is checked by performing a Bell test. A common version is called a CHSH inequality which yields an S value which must be above 2, higher means better quality. Typical values are 2.4 and have experimental accuracy to 4 or more standard deviations.
Once you have a good source, you can perform other experiments.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
