Physics Articles and their Voice (grammatical)
  • Thread starter Thread starter Hepth
    Articles Physics
I see a lot of different ways to write physics articles and I'm wondering if there is a preferred, or even a required voice for writing articles (Say something submitted to PRL).
If I'm alone as an author, or with someone else, etc can I use:
Using the values found in [3] I calculate the blah
or
Using the values found in [3] WE calculate the blah
or
The blah is calculated using the values found in [3].
While the third SEEMS like the best way to write something non-personal, it seems quite difficult to do for an entire paper.
If the passive gets too heavy-going, you can say
Using the values found in [3] one calculates the blah (or, one can calculate the blah)
"We" is probably OK. I would avoid "I" even if you are the sole author, unless you really are expressing your own opinion, for example in a book review, or an invited paper that is a summary of a work in a particular field or by a particular person.
First, I have always felt that clarity is the most important thing. This is more important than following some rule.
Second, passive is generally preferred, so long as it doesn't conflict with rule one. And I've seen some really impenetrable text trying to shoehorn everything into the passive voice.
Finally, I have no problem with "I" in a single author paper, although not all my colleagues feel that way.
As a referee, I have zero problem with someone using "I" when it is a paper with a single author. I forget who is the physicist that quite often use that when he's the sole author.
As Vanadium said, I am more concerned about the clarity and content of the paper. Still, sometime, going too far of the usual path can be distracting, so you don't want to do that either.
Zz.
