Physics Dynamics: Angular and Linear Motion of Machine Components
  • Thread starter Thread starter tom23
    Dynamics Physics
5 replies · 3K views
tom23
Gear ‘B’ on the machine shown below accelerates from rest to 250 rpm in 2 seconds. Determine the angular velocity and acceleration of A, and the linear acceleration and velocity of rack C. See image attached
I don't know where i would start off with this question, help would be appreciated.
Welcome to PF!
Hi tom23! Welcome to PF!:smile:
(how far apart are the teeth on B compared with A and C? :confused:)
First find the angular velocity and acceleration of B.
Then you know that the "tooth-rates" on A B and C are the same … eg if B rotates through 7 teeth of the cog, then both A and C also move through 7 teeth. :wink:
So I got this until now, is it right?
ang velocity = 250 rpm x 2 pi x (1/60) = 26.2 rad/s
ang acceleration = change in ang velocity / chang in time = 26.2 rad/s / 2s = 13.1 rad/s^2
Thus at B: tangential Velocity at B = ang velocity*radius1 = 26.2*20 = 524 cm/s
tangential Acceleration at B = ang acceler.*radius1 = 13.1*20 = 262 cm/s^2
Therefore on A:
Angul. Velocity at A = tang. velocity/radius2 = 524/15 = 34.9 rad/s
Angul. Acceler at A = tang. acceler./radius2 = 262/15 = 17.5 rad/s
Does this two answers sound right, now how would i go on to solve for linear accel. and velocity of rack C?
Yes, that's fine. :smile:
Therefore on A:
You haven't answered my question: how far apart are the teeth on B compared with A and C?
If they're the same distance apart, then your answer is right.
Same method … you have the tangential velocity of A, so you can find the linear velocity of C.
Tey didnt give the distance, so i believe it is the same, so for linear velocit and accel at C, i got:
V = 34.9 (30cm) = 1047 cm/s
a = 17.5 (30cm) = 525 cm/s
Does it look right?
Thanlks for all your help above!
Hi tom23! :smile:
Does it look right?
Yes … that's fine … if the teeth are all the same distance apart, then the tangential velocities and the linear velocity are all the same. :smile:
(though I'd have done it directly from B … 26.2(40), rather than from A, as you did! :wink:)
