Physics Dynamics: Angular and Linear Motion of Machine Components
  • Thread starter Thread starter tom23
    Dynamics Physics
Gear 'B' accelerates from rest to 250 rpm in 2 seconds, leading to an angular velocity of 26.2 rad/s and an angular acceleration of 13.1 rad/s². The tangential velocity at Gear 'B' is calculated to be 524 cm/s, with a tangential acceleration of 262 cm/s². For Gear 'A', the angular velocity is determined to be 34.9 rad/s and the angular acceleration 17.5 rad/s². The linear velocity and acceleration of rack 'C' are found to be 1047 cm/s and 525 cm/s, respectively, assuming uniform tooth spacing across the gears. The calculations are confirmed to be correct based on the provided parameters.
tom23
Gear ‘B’ on the machine shown below accelerates from rest to 250 rpm in 2 seconds. Determine the angular velocity and acceleration of A, and the linear acceleration and velocity of rack C. See image attached
I don't know where i would start off with this question, help would be appreciated.
Welcome to PF!
Hi tom23! Welcome to PF!:smile:
(how far apart are the teeth on B compared with A and C? :confused:)
First find the angular velocity and acceleration of B.
Then you know that the "tooth-rates" on A B and C are the same … eg if B rotates through 7 teeth of the cog, then both A and C also move through 7 teeth. :wink:
So I got this until now, is it right?
ang velocity = 250 rpm x 2 pi x (1/60) = 26.2 rad/s
ang acceleration = change in ang velocity / chang in time = 26.2 rad/s / 2s = 13.1 rad/s^2
Thus at B: tangential Velocity at B = ang velocity*radius1 = 26.2*20 = 524 cm/s
tangential Acceleration at B = ang acceler.*radius1 = 13.1*20 = 262 cm/s^2
Therefore on A:
Angul. Velocity at A = tang. velocity/radius2 = 524/15 = 34.9 rad/s
Angul. Acceler at A = tang. acceler./radius2 = 262/15 = 17.5 rad/s
Does this two answers sound right, now how would i go on to solve for linear accel. and velocity of rack C?
Yes, that's fine. :smile:
Therefore on A:
You haven't answered my question: how far apart are the teeth on B compared with A and C?
If they're the same distance apart, then your answer is right.
Same method … you have the tangential velocity of A, so you can find the linear velocity of C.
Tey didnt give the distance, so i believe it is the same, so for linear velocit and accel at C, i got:
V = 34.9 (30cm) = 1047 cm/s
a = 17.5 (30cm) = 525 cm/s
Does it look right?
Thanlks for all your help above!
Hi tom23! :smile:
Does it look right?
Yes … that's fine … if the teeth are all the same distance apart, then the tangential velocities and the linear velocity are all the same. :smile:
(though I'd have done it directly from B … 26.2(40), rather than from A, as you did! :wink:)
