Physics Emergency: Two Trains Moving Away at 51% Light Speed
  • Thread starter Thread starter Rico Bamchug
    Physics
The discussion centers on the relativistic effects of two trains moving away from each other at 51% the speed of light (0.51c). It clarifies that, according to the relativistic velocity addition formula, one train will not appear to be traveling at 102% the speed of light, but rather at approximately 80.946% the speed of light (0.80946c) as measured from the other train's frame. The importance of specifying the reference frame when discussing velocities in relativity is emphasized, ensuring clarity in communication.
  • Understanding of special relativity principles
  • Familiarity with the relativistic velocity addition formula
  • Basic knowledge of the speed of light as a constant
  • Concept of reference frames in physics
  • Study the relativistic velocity addition formula in detail
  • Explore the implications of special relativity on time dilation and length contraction
  • Learn about reference frames and their significance in physics
  • Investigate real-world applications of special relativity in modern technology
Students of physics, educators explaining special relativity, and anyone interested in understanding the nuances of high-speed motion and its effects on perception and measurement.
Rico Bamchug
Okay, I made a statement in another forum completely unrelated to physics and I believe it to be wrong even though I made the statement in good faith. (Which is to say, I THOUGHT I knew what I was talking about.)
So please, if you can, bail me out.
Two trains are moving away from each other, both traveling at 51% the speed of light. In one train, viewing the other, would it appear to be traveling at 102% the speed of light?
Okay, that's it! Any help will be greatly appreciated!
Nope, you have to use the relativistic velocity addition formula here--in one train's frame, the other train will be moving at (0.51c + 0.51c)/(1 + 0.51^2) = 0.80946c, i.e. 80.946% the speed of light.
Awesome! And thank you Jesse!
Whenever you talk about this kind of problem, it helps to always add "as measured ..." When you say a train is moving at 0.51c, state relative to what or measured relative to what. That helps keep things straight.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 83 ·
  • · Replies 51 ·
