Physics Forums experiencing severe slowness and database errors
- Thread starter Borek
- Start date
403 replies · 66K views · last reply
jhae2.718
- 20
I had similar problems with 66.228.118.186 last Saturday.
FtlIsAwesome
- 0
I have Avast and I have not seen any popups when visiting PF.
turbo
- 57
Sunday afternoon/evening, PF died for me. I don't know if this was a widespread issue or if there were issues on the path between here and there.
- 22,170
- 3,335
turbo-1 said:Sunday afternoon/evening, PF died for me. I don't know if this was a widespread issue or if there were issues on the path between here and there.
See https://www.physicsforums.com/showthread.php?t=495194
It were no hackers, luckily...
FtlIsAwesome
- 0
How do you know? It could be the hackers breaking into the power supply manually!micromass said:See https://www.physicsforums.com/showthread.php?t=495194
Homework Helper
MHB
- 16,335
- 258
Borek said:Is it just me, or is the forum slow today? For most of the time it goes OK, but then for a minute or two it freezes.
Right now the forum is responsive.
But earlier today I got a couple of gateway timeouts that other people apparently didn't have.
When I watched what my browser was doing before a timeout, I saw that it happened when it was accessing mathjax.org...
I'm not sure yet however, that mathjax.org is the reason...
Staff Emeritus
- 614
I like Serena said:Right now the forum is responsive.
Yep, I got that too, a few times now. I'm using Chrome, and I get a message I've never seen before that mentioned mathjax. Nothing is responsive, not even the cursor. Lasts about 10 seconds.
- 20,010
- 11,146
lisab said:Yep, I got that too, a few times now. I'm using Chrome, and I get a message I've never seen before that mentioned mathjax. Nothing is responsive, not even the cursor. Lasts about 10 seconds.
please record the message next time it appears, thanks!
- 3,266
lisab said:It was only a couple seconds this time:
Loading [MathJax]/jax/output/HTML-CSS/jax.js
Happens when I open Random Thoughts.
This may be one of those case when you're getting the fonts from MathJax and they are a bit slow. I loaded the STIX fonts into my Win 7 Fonts folder and Firefox is lightning fast. Might be worth a try; if it can be done in Chrome.
DaveC426913
2025 Award
- 24,768
- 9,191
I now get some sort of mathjax.js echo on a blank screen before the forum comes up.
mishrashubham
- 599
- 1
Mentor
- 29,220
- 4,662
mishrashubham said:Now I am getting 504 errors. Although I think that is not some problem with PF.
This is PF problem, from what I remember nginex was added to help deal with DDOS attack, since then it sometimes gives 502 and 504 errors, at least for me. I have never seen these errors before DDOS attack.
IMHO MathJax problems are unrelated and appear when MathJax servers are not fast enough. Unfortunately Opera seems to deal incorrectly with such situations
- 20,010
- 11,146
DaveC426913 said:I now get some sort of mathjax.js echo on a blank screen before the forum comes up.
can you elaborate? what are you doing when this happens? does it happen all the time?
Evo
Staff Emeritus
- 24,114
- 3,277
It happens anytime you enter a thread, sometimes it goes so quickly that you really have to be looking for it to see it. This is the message.
www.physicsforums.com/clientscript/mjsettings.js[/URL]
I started noticing it last week. I saw that you were discusing the issue Greg, or at least I thought that was what you were discussing. I'll pm you.
- 11,146
MathJax is dependent on the Amazon CloudFront so there is little they can do in terms configuring that. One developer asked if anyone here would be willing to install a plugin that would collect data that would be useful in troubleshooting the loading problems. PM me if interested.
Mentor
- 29,220
- 4,662
Code:
borek@invincible ~ $ ./checkPF
PING physicsforums.com (74.86.200.109) 56(84) bytes of data.
--- physicsforums.com ping statistics ---
10 packets transmitted, 0 received, 100% packet loss, time 8998ms
traceroute to physicsforums.com (74.86.200.109), 15 hops max, 40 byte packets
1 192.168.0.7 (192.168.0.7) 0.606 ms 0.568 ms 0.524 ms
2 10.0.0.138 (10.0.0.138) 1.064 ms 0.990 ms 0.950 ms
3 * * *
4 xxxxx.tpnet.pl (xx.xx.xx.xx) 23.406 ms 23.614 ms 25.603 ms
5 hbg-b2-link.telia.net (213.248.89.93) 40.144 ms 40.535 ms 40.570 ms
6 hbg-bb2-link.telia.net (80.91.251.81) 46.344 ms 40.094 ms 39.173 ms
7 nyk-bb2-link.telia.net (80.91.247.123) 125.381 ms nyk-bb2-link.telia.net (80.91.247.125) 123.475 ms 124.499 ms
8 dls-bb1-link.telia.net (213.155.130.67) 165.859 ms dls-bb1-link.telia.net (213.155.130.209) 164.422 ms 165.928 ms
9 te3-3.bbr02.eq01.dal01.networklayer.com (213.248.102.174) 169.799 ms 170.488 ms 170.192 ms
10 po6.dar02.sr01.dal01.networklayer.com (173.192.18.213) 170.019 ms 170.199 ms 170.734 ms
11 po2.fcr03.sr04.dal01.networklayer.com (66.228.118.190) 171.852 ms * 170.112 ms
12 * * *
13 * * *
14 * * *
15 * * *
For over two hours I was cut off (starting around 21:32 my time). And it had nothing to do with yesterdays situation
Mentor
- 29,220
- 4,662
Again, my IP seems to be blocked, I can use some random free proxy to connect to PF, but for some reason server doesn't like my current address. Previous post was from the IP assigned by my ISP, the one that is blocked. Pings don't pass through. Seems like nobody else has problems.
I wonder if I am not blocked because some of IPs in my range are blacklisted? They are assigned dynamically once per 24h, so blocking them doesn't make much sense.
I will try to reset modem, perhaps I will get a new IP this way.
Homework Helper
MHB
- 16,335
- 258
Borek said:Resetting modem helped, so there is no doubt it is IP related.
Did you get a different IP?
Because usually you get a "lease", meaning you'll get the same IP until the lease expires.
Evo
Staff Emeritus
- 24,114
- 3,277
Throws net over Borek.Borek said:Resetting modem helped, so there is no doubt it is IP related.
Sit, stay!
Oh wait, this isn't chat.
Evo
Staff Emeritus
- 24,114
- 3,277
I like Serena said:Did you get a different IP?
If you have a dynamic IP address, you'll only keep that address until you disconnect from your ISP, the next time you log on, you will be given another IP address from you ISP. ILS, is that what you mean by a *lease*?Borek said:Completely different, 79.185.*.* vs 83.6.*.*.
Homework Helper
MHB
- 16,335
- 258
Evo said:Throws net over Borek.
Sit, stay!
Evo said:If you have a dynamic IP address, you'll only keep that address until you disconnect from your ISP, the next time you log on, you will be given another IP address from you ISP. ILS, is that what you mean by a *lease*?
I was just verifying that there was indeed an actual change in IP before assuming that the old IP was blocked.
It seemed unlikely that Borek wouldn't have checked, but sure is sure. :)
If you're interested, the concept of a lease in this context is for instance explained here:
http://en.wikipedia.org/wiki/Dynamic_Host_Configuration_Protocol"
Evo
Staff Emeritus
- 24,114
- 3,277
Ah, well I worked for AT&T that developed the internet for the US government. I worked on data networks from the early 70's. Never heard that term, we never used it. Someone posting on wikipedia wouldn't know that. <insert Aflac duck here> nah, nah.I like Serena said::)
This must be a term that cropped up after the 70's. (Shows how old I am). :(
jhae2.718
- 20
If, for some horrible, unfathomable reason, you are on Windows, maybe try:
Code:
ipconfig \release
ipconfig \renew
StevieTNZ
- 1,944
- 837
Evo said:Ah, well I worked for AT&T that developed the internet for the US government.(
You must be smart!
