Physics I- impossible question on oscillation (help needed).
The discussion revolves around a physics problem involving gravitational acceleration inside Earth and the motion of an object dropped through a hypothetical hole. The key formula derived is T = 2(pi)*sqrt(R_E/g_0), indicating that the object would execute simple harmonic motion with a period equivalent to that of a satellite in low Earth orbit. Participants confirm that both periods are the same, highlighting an interesting result in the relationship between oscillation and circular motion. The conversation also touches on the equations governing simple harmonic motion and constant circular motion, emphasizing the connection between angular velocity and frequency. Overall, the discussion clarifies the physics concepts involved in the problem and confirms the validity of the findings.
frasifrasi
The question is
"The magnitude of the gravitational acceleration inside Earth is given approximately by g(r) = g_0(r/R_E), where g_0 is the surface value, r is the distance from Earth's center, and R_E is Earth's radius; the acceleration is directed toward Earth's center. Suppose a narrow hole were drilled straight through the center of Earth and out the other side. Neglecting air resistance, show that an object dropped into this hole executes simple harmonic motion, and find an expression for the period. Evalueate and compare with the period of a satellite in a circular orbit not far above Earth's surface."
I am gettinng that T = 2(pi)*sqrt(R_E/g_0)
How do I proceed from here? I am lost! I tried comparing and equations and think that R = RE, and their periods are exactly the same. is this correct?
I think your answer is correct. Have confidence in your reasoning. :-) Their periods are exact means that you found an interesting result!
First question is related to simple harmonic oscillation: \frac{d^2r}{dt^2}=-\frac{g_0}{R_E}r where \omega=\sqrt{\frac{g_0}{R_E}}. And second problem is related to constant circular motion: a=\frac{v^2}{R}, where a=g_0, v=\omega R_E, R=R_E so same \omega. But you should pat attention to the relation between angular velocity and frequency \omega=2\pi f
Ok, thanks. My work is very similar to yours--is that enough to answer the question? The reason I ask is because this is an end of chapter question, which is supposed to be one of the harder ones.
# It would enough for me if I were your teacher.
How did you get that velocity?
isn't velocity supposed to be:
v^2 = v_0^2 + 2ax ?
= v = sqrt(Rg_0) ?
thanks and sorry about no latex.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
