Physics power question frustrating me
6 replies · 2K views · last reply
thereddevils
Two bulbs P and Q labelled 12V , 24 W and 12 V and 36 W respectively are connected in series with a battery 24 V . Among the following statements , which one describes correctly about bulb P and Q
(a) potential difference across P > pd across Q
(b) resistance of Q > resistacne of P
(c) current passing through Q > current in P
(d) power dissipated from Q > power dissipated from P
(e) potential difference and current in both bulbs are the same
For (a) , i don think its right , since from P=VI , where I is constant here , when P increases ,V also increases .
For (b) , i think its correct because from P=I^2 R , when P increases , R also increases .
(c) its not correct since the current passing through both bulbs are the same
(d) this is also correct , since given that Q is 36 W and P is 24 W
(e) this is incorrect .
Is my reasoning for each correct ?
What does one mean when one says "a light bulb is labeled 12 V and 24 W"? What information can be extracted from this?
the potential difference across it is simply 12 V and the power it requires to light is 24 W , is it that simple ? And also the current is 2 A .
Not quite. A light bulb will give some light even if the applied voltage is less than the rated voltage. It means that when 12 V is applied to the bulb, the power dissipated in it will be 24 W. Can you use this information to find the resistance of the bulb?
oh , yeah , P=V^2/R so when the power dissipated from the bulb is higher when the same amount of voltage is supplied to the bulb , the resistance will be higher .
so (b),(e), (c) are out .
is (d) correct ?
Why don't you calculate the power dissipated in each resistor and answer your own question?
ok , thank you for your help .
