Physics problem kindly explain how to arrive the answer.
  • Thread starter Thread starter herbgriffin
    Explain Physics
5 replies · 2K views
herbgriffin
Two trains start at the same time from stations A and B (6km apart ) respectively in opposite tracks. train A accelerates uniformly at the rate of 0.5 meter per second square until it reaches a speed of 54 kmph, while train B accelerates uniformly at the rate of 0.6 meter per second square until it reaches a speed of 72 kmph and then travels at this speed. Determine when and where both will cross each other
i don't know what equation to use...
i tried equating there distance but it will just complicate the equation...
please help...i would like to know how to get the answer..
hi herbgriffin! :wink:
start by writing out the two equations for the positions of the two trains at any time t (put the origin, x = 0, at A) …
what do you get? :smile:
i will get train a will be 225 m at t=30s while train b is 333.33 m at t=33.33s. I don't know if this is right...
no, write two equations
always write equations!
x=15+[(1/2) (0.5)t^2] train A
x= 20+[(1/2) (0.6) t^2] train B
please correct me if i am wrong i am really confused
hi herbgriffin! :smile:
(try using the X2 icon just above the Reply box :wink:)
your 1/2 (0.5)t2 and 1/2 (0.6)t2 parts are correct,
but i don't understand where your 15 and 20 come from :confused:
also you haven't shown them traveling in opposite directions,
and you haven't dealt with the steady motion after each trains reaches its cruising speed
