Physics Problems, could you tell me if I did them right?
8 replies · 6K views · last reply
Ion1776
1. A parent pushes a baby stroller from home to daycare along a level road with a force of 38 N directed at an angle of 30° below the horizontal. If daycare is 0.83 km from home, how much work is done by the parent?
(38N)(cos(-30))(.83km or 830m)=?
2. You have a 0.750 kg picture frame on a mantle 1.50 m high. How much work was required to lift the frame from the ground to the mantle?
0.750*9.80=7.35N(1.50)=11.025 J
3. You lower a 2.50 kg textbook (remember when textbooks used to be made out of paper instead of being digital?) from a height of 1.81 m to 1.50 m. What is its change in potential energy?
1.81-1.50=.31
(2.50kg)(9.80)(.31)
=7.60 J
Please if someone could confirm these, please be sure of the answer before responding, Thanks so much
The two last ones look correct, but your calculation on the first one doesn't make sense. Please explain, you're correct that E = F * d, but why is d = 10 km?
Wouldn't it be that d = 830 m and that F = 38 * cos 30? (cos 30 = cos -30) Then E = 27 kJ
My equation is W=(Fcos(theta))(change is direction x)
is it (38)(cos(-30))(.83)=27.3144 J
Haven't seen the above equation you're referring to before, but in the lower one: Remember, you must use 830 m and not 0,83 km, the definition of force is kg * m/s^2.
alright.
Could someone else work these problems and confirm if i did them right
I'm sorry, I'm a little confused. The formula (W = F cos(theta) * Change in direction) is the same as E = F * d, it's just a different notation.
I'm still curious where 10km came from though.
