What is the cause of overloading in Pico PSU 120 power supply?
  • Thread starter Thread starter Chandra214
The Pico PSU 120 power supply is experiencing overloading issues when powered by a 5A regulated DC supply, consuming more than 5A without any load connected. Users note that both units tested exhibit the same problem, prompting inquiries into potential causes. The FAQ indicates that initial current consumption may exceed 5A due to the buck-boost topology used in the design. It is also suggested that the power supply may have a minimum output current requirement for stable operation. The Pico PSU is typically used as a replacement for standard SMPS in mini-ITX motherboard setups.
Chandra214
hi all,
we have problem powering up the Pico PSU 120 power supply, its been powered up by a 5A Regulated DC supply, instead of an adapter. No load is connected. at this point it is overloading. consuming more than 5A. we have 2 of the units in house and both are having same problem. does anyone has any experience using it?
BTW we are trying to contact the manufacturers on this.
Sorry i was not allowed to post the Url's.
and in one of the FAQ, it is also answered that the initial current consumption may exceed 5A because of the buck boost topology incorporated.
Send me a PM with the links, and I'll post them for you. Is this power supply an off-line supply, which takes AC Mains input, and gives some DC output? What are the specifications? You say you power them up with no load, but many power supplies have a minimum output current requirement to stay stable and in regulation.
this is just a replacement for SMPS, where power requirements are not a high as it would be in standard Computer system. it is normally used with mini-itx motherboards.
it takes 12VDC as i/p.
Berkeman, i have posted the links to you as a PM.
Thanks
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 27 ·
  • · Replies 39 ·
15K
12K
