Homework Helper
- 30,593
- 7,548
@Andy Resnick
I wouldn't have thought that my comments about the 'best' order in which to perform processing and data compression should need specific evidence at this time. Is there any argument against that? Once a non linearity is introduced, it is very often impossible to correct for all the distortions that have been created. If that statement is in question here then I should have to dig down into established texts. But I think you know what the result would be. You can't undo the jpeg algorithms or every reconstructed picture could be without any of its artifacts.
What you have to say about "Scientific Images" could well be true but it wasn't clear which was which. The reason is not clear why those two ('scientific'?) graphs should look so different in detail. One of them has definite ringing on it - was there absolutely no processing on it at all? The printed pictures look very detectably different because they are different - and in more than just 'gain'. You seemed to imply that the HF content was irrelevant. I made what I thought was a reasonable comment about that. I'm still not clear about your reasoning. How do they relate to ordinary camera images?
On the subject of Jpeg vs Raw. If you can't tell the difference then I can only suggest that your camera must have unbelievable metering, the subjects you photograph are all extremely kind to photo sensors or that you are not highly critical of picture quality.
Having recently moved from a slow to a faster computer, I can sympathise with you if you find the Raw processing takes a while on a slow machine. Personally, I was always prepared to wait on the old computer because it was only on transferring large files (for every picture) and working on a few selected files that time was a particular issue. Feel free to continue to use your Jpeg images but, when you find a really 'good one' - but for the fact that it has its highlights a tad burned out or the shadows lacking any detail - you may reconsider. You really do seem to be a bit more touchy about this than I would have expected.
Your chosen pictures show that there is loads of info in a reasonable picture, taken with some light by a home camera. However, you may not have actually wanted to have that high amount of noise in the purple areas. In the event that you didn't, a Raw version could well have much reduced noise whilst still not burning out the Sun. You have the option.
The picture of the sand was picked, by you, to demonstrate a point. There is plenty of detail in it but what about the colourimetry? Was it as you wanted? How near the original is it? If you don't care about that then fair enough but what if it had been someone's face, under those same lighting conditions? I'm sure you would be more fussy. In which case, a good colour balance adjustment would be very handy. I might suggest that, unless yo are pushed for storage on camera card or hard drive, you could store both versions and work in Raw on the ones you want to 'present'.
You wrote "you don't need high end equipment to produce high quality images". Many images may be pleasant, they may be what you wanted but reliable quality (fidelity?) is another matter. If you are not concerned with this then I wonder why you are posting on this particular thread?
