Picture sharpness and air effects
79 replies · 16K views
@Andy Resnick
I wouldn't have thought that my comments about the 'best' order in which to perform processing and data compression should need specific evidence at this time. Is there any argument against that? Once a non linearity is introduced, it is very often impossible to correct for all the distortions that have been created. If that statement is in question here then I should have to dig down into established texts. But I think you know what the result would be. You can't undo the jpeg algorithms or every reconstructed picture could be without any of its artifacts.
What you have to say about "Scientific Images" could well be true but it wasn't clear which was which. The reason is not clear why those two ('scientific'?) graphs should look so different in detail. One of them has definite ringing on it - was there absolutely no processing on it at all? The printed pictures look very detectably different because they are different - and in more than just 'gain'. You seemed to imply that the HF content was irrelevant. I made what I thought was a reasonable comment about that. I'm still not clear about your reasoning. How do they relate to ordinary camera images?
On the subject of Jpeg vs Raw. If you can't tell the difference then I can only suggest that your camera must have unbelievable metering, the subjects you photograph are all extremely kind to photo sensors or that you are not highly critical of picture quality.
Having recently moved from a slow to a faster computer, I can sympathise with you if you find the Raw processing takes a while on a slow machine. Personally, I was always prepared to wait on the old computer because it was only on transferring large files (for every picture) and working on a few selected files that time was a particular issue. Feel free to continue to use your Jpeg images but, when you find a really 'good one' - but for the fact that it has its highlights a tad burned out or the shadows lacking any detail - you may reconsider. You really do seem to be a bit more touchy about this than I would have expected.
Your chosen pictures show that there is loads of info in a reasonable picture, taken with some light by a home camera. However, you may not have actually wanted to have that high amount of noise in the purple areas. In the event that you didn't, a Raw version could well have much reduced noise whilst still not burning out the Sun. You have the option.
The picture of the sand was picked, by you, to demonstrate a point. There is plenty of detail in it but what about the colourimetry? Was it as you wanted? How near the original is it? If you don't care about that then fair enough but what if it had been someone's face, under those same lighting conditions? I'm sure you would be more fussy. In which case, a good colour balance adjustment would be very handy. I might suggest that, unless yo are pushed for storage on camera card or hard drive, you could store both versions and work in Raw on the ones you want to 'present'.
You wrote "you don't need high end equipment to produce high quality images". Many images may be pleasant, they may be what you wanted but reliable quality (fidelity?) is another matter. If you are not concerned with this then I wonder why you are posting on this particular thread?
I'm not sure how to respond- I think you are mixing up concepts, or at least not understanding me.
I don't understand why you care so much about what I do.
I posted on this thread because I was directly asked a question.
Andy Resnick said:
PF is a scientific forum- claims are supported or refuted with evidence, not by appeals to authority or anecdotal evidence.
Members are not required to conduct their own experiments to back up every claim. This is pretty mainstream stuff being discussed in this thread, not some outlandish claims along the lines of faster-than-light travel (just for example).
Yes, I have had mixed messages, I think. I am still not exactly sure which imaging method is referred to in some of your past posts. What message should be taken from the \scientific' images that would translate directly to ordinary photography?
I am actually interested in the technical matter of those two 'scientific' images and the clear differences between the two graphs. Do you still think that the apparent difference in their perceived sharpness is due to level and nothing to do with the different HF content? I should have said that there is sufficient difference between the two pictures to account for what they look like. Did I miss something? The automatic sharpening in point and shoot cameras is very relevant to subjective performance.
I don't particularly care what you, personally, do about your photographs but I do care that people who read what you write may take you literally and miss out on a useful photographic tool such as Raw processing. You are credited as being a Science Advisor, which would mean that what you write will be taken more seriously than idle chit chat. I, certainly have found that many of the things you write make excellent sense. I feel that you could have qualified your stated preference for Jpeg on the grounds of your colour vision and a slow computer and helped to avoid misunderstanding about its real relative merits. Was there anything else to 'misunderstand' about your comments about Raw vs Jpeg?
Perhaps. But sophiecentaur made specific claims about *my* images.
sophiecentaur said:
From the look of the two graphs, it seems to me that the second picture could have had had some 'aperture correction' processing. The slope is increased and there is a slight ringing before and after. That is a common 'sharpening' method which accentuates edges and makes them more noticeable. <snip>
When, as a point of fact, both images were treated identically.
sophiecentaur said:
I<snip>Raw is the way forward for serious photography. Jpeg is the equivalent of the Instamatic, by comparison.
This is silly.
sophiecentaur said:
<snip>If you are interested enough to be discussing things at this level you can't justify sticking to jpegs. Pros use RAW for a good reason.
This is likewise silly. I'm not a professional photographer, nor have I ever claimed to be one.
Then, after two lengthy posts with detailed explanations about I'm not sure what exactly- proselytizing? cajoling? patronizing? possibly some denigrating...
sophiecentaur said:
<snip>
sophiecentaur said:
<snip>
which included additional (incorrect) claims about *my* images,I get this:
sophiecentaur said:
Yes, I have had mixed messages, I think. I am still not exactly sure which imaging method is referred to in some of your past posts. <snip>
So... why exactly should I be dealing with this foolishness?
sophiecentaur said:
Yes, I have had mixed messages, I think.<snip>
Let me ask you this: When I wrote
Andy Resnick said:
<snip>
You are free to use whatever tools you wish to create an image. Again, and I thought I was being clear about this, in my *personal experience* taking non-science images, I have no use for the RAW data format. *For me personally*, it's not worth the order of magnitude difference in file size or time required to sit and wait for the computer. *Personally*, I prefer to take photos rather than stare at a computer monitor. YMMV.
Why did you (apparently) interpret that to mean that RAW is a useless format?
It's perfectly fine to have personal opinions and to share experiences. Not that I imply that anybody did that, but I think it's also prudent to avoid carefully to spread popular no brainers like go-for-the-glass, when it is obvious that things are much more complex. Then I have a tendency to show that. Like also what useful but hidden information can be stored in RAW.
If you're always happy with jpg and you know what you're missing, sure by all means.
I'm very aware about the bit and time consuming habits of RAW, so for the series of hundreds snapshots on the toddlers birthday party, I use jpg, nobody is interested if the blurred window in the back is washed out or not.
I may use jpg -not always- shooting high dynamic action with 8 frames per second, to avoid the buffer getting saturated after a few seconds, and slowing down the frame rate. JPG continues indefinitely until the battery is empty or the card is full, so that may be a consideration sometimes.
I certainly use raw for studio, macro and landscaping in combination with a small jpg frame, which I use as thumbnail, selecting the best shots, so that I don't have to wait behind the computer for the long time it takes processing all the raws, of which a lot would be trashed anyway.
Luckily the camera allows to store all those very different settings as user profiles, so switching from toddler single snapshots in jpg to a multi frame sequence of a bird in flight in raw, is one click of the dial
@Andy Resnick
Let's forget the Jpeg issue. Do you have a problem with people disagreeing with you in areas of your expertise?
I should still be interested in your comments about the visibility of those two images. For whatever reason, the two graphs are different in detail and so is the image visibility. You are saying it's all to do with level. Is it "silliness" to ask why, when another factor is in play? Could it be something subtle like the way the array is read? No need to be prickly about this one.
<snip>
Well, that's exactly the issue here- you haven't said anything to disagree *with*. Instead, you offer reflexive braying about why *my* images are irretrievably degraded and of poor quality, and how I have no business talking about this issue.
Here's a 1:1 crop of a color image I took last night. I cannot detect any meaningful signs of detail loss through data compression:
[PLAIN]http://img839.imageshack.us/img839/4546/dsc10251.jpg
And before you confuse the data compression associated with displaying the image here with the actual image, here's a 1000% crop of a region of the above image. Where, exactly, is the dreaded loss of information from data compression?
[PLAIN]http://img801.imageshack.us/img801/9494/dsc102512.jpg
Again, my issue is simply that you are making unsubstantiated claims about *my* images.
While this "conversation" has been going on, I've taken 200 photos. That would be 20 GB of uncompressed data to deal with. In a week. Every week. That is not how I want to spend my time, especially since I have so much to learn about composition, lighting, and creating a photograph that can clearly communicate an idea. Pixel peeping is *way* down on my list of priorities.
The only expertise I have proffered here is in regards to the analysis of optical systems- not the design of optical systems, and certainly not the post-processing of images.
I liked the "braying" comment. You really are ratty about this aren't you. Why? All the pictures (all pictures) have faults and is there anything wrong with pointing them out? This isn't a Photo Forum and there is no artistic evaluation of any of them in my comments. Why be so precious when I say that I can see noise and probable colour mismatch? You have said tht you have non-standard colour vision so why be surprised that someone can see something in a picture that you cannot? If you really aren't concerned with quality then why not just use your 'phone - or your Wife's camera.
The picture of the Moon - very nice to look at - has low contrast and low detail, as one might expect from a non-NASA image. JPeg doesn't need to work very hard to compress it so there are no visible artifacts. We all know the sort of picture that Jpeg slaughters and that blowing up pictures of fine structures like nearby trees against the light will crawl with visible artifacts that won't be there in RAW. You seem to be wearing two hats for this thread. Your 'science' hat is objective but your other 'Photographer' hat seems to make you a tad more sensitive than is useful. Why are you offended by valid comments about pictures just because they happen to be yours? I do the same and worse to my own and I don't kid myself that they're high quality when they're not.
We will just have to draw a line under that one. But, I would still like to see an objective response to my comments about the b/w images and the graphs. I ask again why you say the difference in apparent detail is just due to level when the hf content is so clearly (no?) different, according to the graphs. There may be a good answer and I should be genuinely interested to know.
sophiecentaur said:
<snip>If you really aren't concerned with quality then why not just use your 'phone - or your Wife's camera.
<snip>
Picture sharpness is only one of many compositional elements I consider. There are lots of times when I prefer to use my wife's camera- for example, when we are backpacking or traveling and I don't want to carry around mine, or if I am in a 'dirty' environment (dust/sand/salt air, etc) and I don't want to risk damage to my camera.
I got the sony because I wanted a color camera for the lab microscopes; 'scientific' color cameras (Jenoptik, Zeiss, Leica, etc) are horribly expensive and have very small image sizes. Recently, consumer electronic companies have come out with 35mm image format color cameras that are significantly less expensive, so I purchased a DSLR, a few adapters and a couple of lenses so that I could use the camera without the microscope.
Once I took a few photos with the 85mm I re-discovered photography (something I hadn't done since high school), now with the benefit of many years of experience using digital imaging systems. Applying quantitative imaging methodology to photography is easy (for me); learning how to use photography as an expressive tool is much harder (for me).
I really don't care about your photography habits. I never was. Neither do I want to upset you when I state only the truth about those pictures you posted. I was just concerned that your personal preference may have caused someone to avoid Raw when it might be of use to them. You are a bit of 'an authority' in these matters and people may take your personal preference as applying to their circumstances too. You would not want that to happen, I'm sure.
I might point out that this thread is,essentially, about picture sharpness at the 'high end', so I'm not sure that the performance of cameras which are carried for 'convenience' / ruggedness comes into this discussion.
Just please tell me (or clarify) what those b/w shots were taken on and whether you can be sure there is nothing 'going on' in the camera that may have produced those different graphs and the reasoning behind your statement about them. Was it a Lab camera (used for your Scientific Imaging) or a domestic digital camera? Can't we just discuss a bit of possibly useful technical evidence that you have submitted?
I may have failed to understand your explanation about that and I'd appreciate a constructive response. Do you understand the point I have made?
All images I post here, unless I say otherwise, are taken with the sony a850. Although I have a good understanding of the behaviors of the various lenses I use, I have no idea about what goes on inside the camera. And it's not relevant to me: single-chip color cameras are not appropriate for metrology.
SO, to help me a bit further, are there, in fact, any shots from other cameras and have you 'said otherwise' on this thread and have I missed it (apart from your Wife's sand shot)? If the b/w shots are from the sony, then do you still not want to comment on graphs and visibilities? What have you to risk?
I still don't know whether there is any actual 'metrology' on this thread. If there isn't then why are you bringing up what you do in your day job? If you choose to ignore the possibility of what goes on inside your sony having an effect then where is the Science in what you are writing?
I don't understand what you are asking (other than identifying cameras- and I have not posted any photos using my EMCCD or my digital video camera except in post 10 of this thread).
Thank you for that confimation. You made a statement about perceived sharpness being related to level. You showed two pictures and two graphs - to illustrate / justify the statement (?). I have asked many times how this evidence justifies your assertion.
Also I have made the point that in-camera processing involves 'sharpening'. You say that you kwow nothing of what your camera does in that respect. You say that one of those pictures looks sharper and I agree. The graph seems to show some edge enhancement. So how do your two pictures justify your statement?
Moreover, with such a big unknown in the signal chain, can one come to any serious conclusion about this?
With Jpeg processing included, the situation is even less certain.
sophiecentaur said:
You made a statement about perceived sharpness being related to level. <snip>.
If I did, that was not my intention. In terms of linear systems analysis, the perceived (meaning visual appearance) sharpness of an image is set by the contrast at midrange spatial frequencies. The cutoff frequency (the 'resolution limit') is less important to the visual appearance than the contrast at midrange spatial frequencies.
There is an excellent discussion of this (contrast sensitivity function) in "Basic Vision" (Snowden, Thompson, and Troscianko)
I think we are nearly there.
It was post 43. You say that the line scans show the image quality is the same. Do they? (This is what I have been questing all the time.) One has what looks like 'ringing' and enhanced local contrast on it and that, as I have mentioned several times, looks a lot like what you get when sharpening has been used.
If the images came from your sony then it may have had some of that sort of sharpening (aperture correction type) treatment. Yes, at half amplitude peaks are the same width but there, the similarity ends. Am I totally raving or is this a valid point?
You seem to have been so busy taking offence at my harmless remarks that it is only now that you seem at all receptive - please don't stop.
I'm not sure which is the case- that I've not been clear enough, or that you are insisting on an indefensible position.
I thought I was being very clear all along- single chip color cameras are not appropriate for quantitative image analysis. Pointing to 'data' obtained from a single-chip color camera image and treating that as quantitative information is a bad idea.
My goal of the image comparison was simply this- images from a single-chip color camera that appear grossly different, sometimes cannot be easily distinguished by pixel peeping.
Maybe I am not understanding your position. In that case, I would suggest that you post some images of your own to illustrate what you are trying to say.
My only 'position' is more or less is in total agreement with the third para of your last post. But, from the large number of pictures you have posted on this thread - plus the graphs, you have been giving me the strong impression that you think that there is, in fact, plenty of objective evidence for drawing all sorts of conclusions.
I have made the point that camera processing is probably responsible for many of the differences in perceived sharpness in pictures - hence my opinion about the use of Raw.
I really don't know why you should be wanting to see images of mine to support my ideas. The ones already posted speak volumes. There is a blow up of the sea, with massive 64pixel blocks of random looking patterns which can hardly be bettered as an example of where jpeg clouds the issue. There is a picture of a distant coastline which is blurred, possibly as a result of the long transmission path over the sea and yet the sparkle of the sea just in front of the coastline is apparently very sharp. Having played many times with Photoshop's Unsharp Mask I know that you can produce exactly this effect with selective sharpening. What use are those pictures in proving or demonstrating anything about atmospheric propagation? Any image that I could submit would be just as pointless.
I think the only pictures that would be worth posting on this thread in order to answer the OP questions would have to be taken on a film camera or a lab camera with monochrome sensor. Bunging a huge imponderable into the signal chain would not be 'good Science', would it?
It would be a pity to find out that we had both, in fact, been shouting the same message but not recognising what the other was shouting.
