Mentor
- 23,212
- 7,701
Deepblu said:I am looking to buy a telescope, what is cheapest telescope I can buy with highest magnification possible?
Except in the case of very small telescopes, your magnification* is often limited more by turbulence in the upper atmosphere than by the telescope itself. Not only that, you don't actually want maximum magnification for about 95% of targets. High magnification causes the image to dim and makes it harder to keep the image stable and to find targets in the first place. I often get a 'better' view of the planets with a relatively low power eyepiece instead of one that gives me the highest possible magnification I can get. My high-mag eyepieces often just make the image a dim, blurry mess. And this is with an $1500 8-inch reflector on a mount that costs just as much.
As for price, I would set a minimum price at around $100 USD (or even $200). Anything less than this and you will almost certainly be buying a very poor quality telescope. Even if the optics of this scope are average, or even good, the quality of the mount, the tube assembly, and the accessories will likely be poor and make the telescope frustrating to use.
Trust me when I say that saving up a little extra to buy a more expensive telescope is well worth the delay.
*Note that a telescope doesn't have a single magnification. Instead the magnification depends on the focal length of the primary optics (the big piece of glass at the front or the big mirror inside) combined with the focal length of the eyepiece you are using. Buying a couple of eyepieces of different focal lengths gives you a good range of magnifications to suit your needs. Many telescopes come with at least 2, one for low-mag and one for high-mag, if I remember correctly.
Deepblu said:I had small telescope with max 40x magnification but I was not satisfied by it, mainly because it was very unstable where the least wind causes shaking and everything I see through it was very blurry including nearby planets like Mars and Venus.
This is most likely because you had a cheap telescope with a light, flimsy mount. I had one as a kid that broke the first night I had it thanks to flimsy plastic threads between the tube assembly and the focuser.
In regards to a specific telescope you should buy, I'm afraid I can't recommend a specific one. There's a saying in amateur astronomy: "The best telescope is the one that you will use." I stand buy that statement. If your nearest viewing location is four flights of stairs down and three blocks away on foot, then you probably don't want a 8-inch dobsonian that you'd need to make two trips for. If you are in a situation similar to this, a good pair of 5-7 inch binoculars might suit you best.
Try looking through this thread for more information: https://www.physicsforums.com/threads/planning-to-buy-a-first-telescope.391086/
