Point charge(Q) has a divergence zero
  • Context: Undergrad
  • Thread starter Thread starter bharath423
    Divergence Point Zero
The divergence of the electric displacement field (D) due to a point charge (Q) is zero when calculated away from the singularity at r=0. However, Gauss's law indicates that the divergence should yield a finite value due to the presence of charge. This discrepancy arises because the divergence cannot be computed at the singularity where the vector field is undefined. To properly apply Gauss's law, one must consider the divergence as a distribution, particularly in the vicinity of singularities, as discussed in Griffith's "Introduction to Electrodynamics."
  • Understanding of vector fields and their singularities
  • Familiarity with Gauss's law and its applications
  • Knowledge of divergence and its mathematical implications
  • Basic concepts of distributions in physics
  • Study Griffith's "Introduction to Electrodynamics" for insights on divergence near singularities
  • Learn about the mathematical treatment of distributions in physics
  • Explore the divergence theorem and its applications in electrostatics
  • Investigate the behavior of electric fields near point charges and their implications
Physics students, electrical engineers, and researchers in electromagnetism who seek a deeper understanding of divergence in vector fields and its relationship with Gauss's law.
bharath423
The D field due to a point charge(Q) has a divergence zero
D = (Q/(4*pi*r2)) ar (ar --- unit vector)
if we calculate the divergence we get zero.
but Gauss law says that the divergence is a finite value not zero because a charge is present in there.
is it that in calculating divergence we also take a particular surface?
where I am wrong? I am confused of divergence..i tried wikipedia but could understand it upto my extent..i think somebody could help me
1.Note the singularity of your vector field at r=0.
2. You cannot make a regular volume integral over a region that includes this singularity, but you can perfectly well form a regular surface integral over a region containing that point in its interior.
3. In order for the premises of Gauss' law to be strictly fulfilled, your function must be defined at ALL points in the region; since this is not the case here, you cannot really apply Gauss' law.
4. It IS possible, however, to construct an irregular volume integral in this case, though, by representing the divergence of your vector field as a Dirac delta "function".
so the divergence at a point shows the sink or source at a given point...so if at r=0 we are able to calculate the divergence then it would be equal to Gauss law result..is that what you are saying?
if that is so, then divergence for every field except at the source of the field, every where it should be zero then..is it true?
We CAN'T compute it at r=0 because the vector field isn't defined there. Therefore, rigorously, it has no meaning trying to apply Gauss' law, and thus, Gauss' law isn't "invalidated" by this case since the vector vield falls outside the class of vector fields Gauss' law is speaking about.
Yes.
so divergence is calculated at a particular point only...then in case we calculate for a surface then we get all the sources and sinks which is nothing but the total charge...and this is what gauss law says ..im correct??
I'd have to disagree with you there. Many quantities in physics are loosley called "functions", but are really distributions. This is true of charge density. For some idealized continuous charge distributions, you can represent the charge density as a function, but most of the time it can only be represented as a distribution. So, since Gauss' Law (for \textbf{E} or \textbf{D}) involves charge density (total or free), which is a distribution, it should be understood that the divergence of \textbf{D} should be treated as a distribution and calculated accordingly.
@bharath423
You need to be careful when calculating the divergence near point, line, or surface charges. The easiest method to find the correct distribution is to calculate the divergence normally everyhwere except near you singularities (in this case, everywhere except a small region around your point charge), and then calculate the flux through any closed surface surrounding a single singularity, and using the divergence theorem, deduce what the divergence must be in the visciunity of that singularity.
For your case, you should take a look at Griffith's Introduction to Electrodynamics where the Author calculates the divergence of \frac{\hat{\mathbf{r}}}{r^2}. IIRC it is near the very end of the 1st chapter.
  • · Replies 18 ·
