Polarization I = Io*cos^2 theta
The discussion focuses on a physics problem involving two polarizers oriented at 38.8 degrees to each other, where only 14.6% of plane-polarized light passes through both. The relevant equation is I = I0*cos²(θ), which describes the intensity of polarized light after passing through a polarizer. Participants clarify that the initial polarization direction of the incident light can be determined by rearranging the equation to find cos²(θ1) based on the known transmission percentage. The final formula derived is cos(θ1) = SQRT{(0.146)/cos²(38.8°)}.
  • Understanding of the law of Malus in optics
  • Familiarity with trigonometric functions and their applications
  • Basic knowledge of polarized light behavior
  • Ability to manipulate equations involving angles and intensities
  • Study the law of Malus and its applications in optical systems
  • Learn about the behavior of polarized light and its interaction with multiple polarizers
  • Explore trigonometric identities and their use in solving physics problems
  • Investigate practical applications of polarization in photography and optical devices
Students and professionals in physics, optical engineering, and anyone interested in understanding the principles of light polarization and its applications in technology.
DAP1MP13
Two polarizers are oriented at 38.8o to each other and plane-polarized light is incident on them. If only 14.6 percent of the light gets through both of them, what was the initial polarization direction of the incident light?
Ok, I'm not exactly sure what this problem is asking for, do they want an angle or what?
So basically the only equation given for this section is I = Io*cos^2 theta.
I did ((cos*38.8)^2)((cos*38.8)^2) = .369...
I don't see how I can solve the problem with just this, I thought maybe I can relate it to Snell's eq., but there is no index (n) given.
Also I know that I-final = 14.6% = .146, but once again I don't really know what to do with this.
Any hints and help will be greatly appreciated.
Thanks...
That equation, the law of Malus, tells you what percentage (of the intensity) of a polarized light beam gets through a polarizer set at an angle of \theta to the incident beam's plane of polarization. (And realize that when a beam passes through a polarizer, the part that survives is totally polarized along the axis of the polarizer.)
You figured out the percentage that got through the second polarizer. So what must have been the percentage that got through the first? (You know the net percentage that got through.)
Thanks Doc Al
So the net amount that got through both polarizers was .369, but it says that .146 got through.
The amount that went through the first would just be (cos38.8)^2 = .607.
I still don't know how this would help me to get the answer...
Through 1st polarizer => .607
Through 2nd polarizer => .369 or .146
How would this information tell you what was the initial polarization direction of the incident light?
Can I get some more help on this please?
Thanks
there are 2 angles involved in this problem.
first, the 2 polarizers are rotated relative to one another by angle θ2=38.8°
then, the plane polarized incident light is rotated relative to the first polarizer by angle θ1.
the total net transmission thru both polarizers is given to be 0.146, so the transmission equation is:
I = I0cos21)cos22)
or rearranging and placing known values into the equation:
I/I0 = 0.146
= cos21)cos22)
= cos21)cos2(38.8°)
cos21) = (0.146)/cos2(38.8°)
cos(θ1) = SQRT{(0.146)/cos2(38.8°)}
Now solve for θ1 to find the incident light angle (relative to first polarizer).
  • · Replies 25 ·
