Polarizer angle and convex mirror magnification problems
  • Thread starter Thread starter riseofphoenix
    Mirrors Polaroid
19 replies · 4K views · last reply
riseofphoenix
:(:(:( Please ease my aching soul by helping me with this...
I submitted this assignment online and I don't know the answers yet or however many I got wrong.
Text of a multiple-choice question about two identical polaroid sheets rotated by angle theta, asking for the angle that transmits 25% of initially polarized light, with options 30°, 60°, 25°, 76°, 45°.
I chose 45 because I know unpolarized light becomes this after going through a polarizer:
Diagram of two stacked polarizers: unpolarized light arrows radiating from a point above, a vertical ray passing through a top polarizer with a horizontal arrow, and a bottom polarizer with a diagonal arrow, with horizontal polarized light arrows between them.
That single line is 180º, so I did 0.25 x 180º = 45º.
Is E the right answer?
Multiple-choice question 3 on a concave spherical mirror: object between focal point and mirror surface; options A to E list virtual/real, enlarged/reduced, upright/inverted combinations.
I chose E…but after seeing this diagram below just now, I think I got the answer wrong and that it's supposed to be B… Is E not the answer?
Ray diagram of a convex mirror: object O on the left, image I virtual, upright and reduced behind the mirror, with focal point F and centre of curvature C marked on the axis.
Multiple-choice question 5 on a convex mirror with radius of curvature 10 cm, asking the object distance for a virtual, upright image four times smaller; options 30 cm, 20 cm, 15 cm, 10 cm, 5 cm.
I chose D…but I don't think it's right…
I did this:
Given:
R = 10 cm
f = -R/2 (since it's convex) = -10/2 = -5
do = ?
M = +4 x (image is upright)
di = -? (image is virtual)
M = -di/do
4 = -di/do
di = -4do
1/f = 1/do + 1/di
1/(-5) = 1/do + 1/(-4do)
-0.2 = 1/do - 1/4do
-0.2 = (4/4)1/do - (1/1)1/4do
-0.2 = (4 - 1)/4do
-0.2 = 3/4do
4do = 3/(-0.2)
4do = -0.6
do = -0.6/4
do = -0.15
Is the answer C? (I chose D originally and I can't change my answer….but now that I've worked it out step by step i think the answer is C)
It is not, and there is no reason to multiply 180° by anything. Using the same argument, 90° would let 50% pass through, which is obviously wrong.
You can analyze this with polarization vectors and projetions on the polarization axis, or with existing formulas (Wikipedia, book, ...).
I did this:
Your result is very small (0.15 cm), there has to be some error in the calculation. I found one here:
4do = 3/(-0.2)
4do = -0.6
So basically all three of them are wrong?
Also, what about question number 3?
Take a spoon and test it.
The graph below is not a concave mirror.
Ok but my answer is still wrong though...
The answer for 3 would have to be D.
Think about which side of the concave surface the image lies in.
If it lies on the left (the same side as where the object resides), it is real. If on the right, then the image is virtual. The focal equation is based on the reference of the surface of the mirror. Positive distance means real and negative distance means virtual.
mfb said:
Did you take the right ("inner") side of the spoon?
What do you mean?
mfb said:
I don't know what is unclear about that question.
Like this, but with an object closer to the mirror.
So the answer IS E.
real (image on front), enlarged, inverted.
riseofphoenix said:
So the answer IS E.
Not for an object lying inside of the focal point.
Why don't you try drawing out a a simple ray diagram?
I forgot how to because I did this back in high school and my teacher (in college) just gave us a simple chart to follow and didn't emphasize the fact that we had to draw a ray diagram. :(
mfb said:
I did not find an image of an object closer to the focal point. The inversion is not there in your problem.
The answer has to be B then...
Ok well since I know I got those top 3 questions wrong...I wouldn't mind moving on to the other questions I wouldn't mind you guys checking for me...
Multiple-choice question 5 on a convex mirror with radius of curvature 10 cm, asking for object distance giving a virtual, four-times-smaller, upright image; options 30, 20, 15, 10 and 5 cm.
I did this:
Given:
R = 10 cm
do = ?
____________________________
M = -di/do
4 = -di/do
di = -4do
1/f = 1/do + 1/di
-0.2 = 1/do - 1/4do
-0.2 = (4 - 1)/4do
-0.2 = 3/4do
4do = 3/(-0.2)
4do = -0.6
do = -0.6/4
do = -0.15
Printed multiple-choice physics question on a spherical convex mirror with radius of curvature 10 cm, asking the object distance for a virtual, four times smaller, upright image; options A) 30 cm, B) 20 cm, C) 15 cm, D) 10 cm, E) 5 cm.
I did this:
Given:
R = 10 cm
do = ?
M = -di/do
4 = -di/do
di = -4do
1/f = 1/do + 1/di
-0.2 = 1/do - 1/4do
-0.2 = (4 - 1)/4do
-0.2 = 3/4do
4do = 3/(-0.2)
4do = -0.6
do = -0.6/4
do = -0.15
Your magnification is wrong. It's 4x smaller, which means ##\frac{d_i}{d_o}## should be less than one since ##\frac{h_i}{h_o}## is reduced.
Oh goodness...
So what should M equal?
riseofphoenix said:
Oh goodness...
Well, it's 4x smaller so what do you think?
I'm sure you can figure this out. Other than that there seems to be nothing else wrong with your calculations.
Well, there is a calculation error in the first post, I mentioned it in post 2:
4d0 = 3/(-0.2)
4d0 = -0.6
