Polynomial Inequalities - Finding the solution set?
7 replies · 5K views · last reply
nukeman
Polynomial Inequalities - Finding the solution set??
Solve the Inequality
2x^3 >-8x^2
Ok I am able to solve this by first figuring out the zeroes, and then testing with regions,
So my answer is x=0 and x = -4 are the zeros of f
BUT... now it says "What is the solution set, and using interval notation.
Using interval notation the answer is (-4,0) or (0, infinity)
HOW do I figure out the solution set and interval notation?
Thanks!
You could sketch the graph which would make it easier to see. Since it is a cubic, with two roots, there's only two ways it can really look.
I guess I'm not sure what your question is. You answered the question correctly: the solution set is any x in (-4,0) or (0, infinity). If you're looking for alternate ways to express this, you could write either
[tex](-4,0)\cup (0,\infty)[/tex]
or
[tex]\{x : -4 < x < 0 \textrm{ or } x > 0\}[/tex]
Yes I know that is the answer jbunniii, but why is it the answer. I don't understand how this is the answer.
Thanks
Your inequality is equivalent to x3 + 4x2 > 0, or x2(x + 4) > 0
For this product to be positive, there are only two possibilities:
1) Both factors are positive.
2) Both factors are negative.
If you explore both of these possibilities, you'll get your solution set.
You know that x = 0 and x = -4 are the only two possibilities for 2x3 = -8x2.
The only thing left to do is to test an arbitrary x value before -4, between -4 and 0, and after 0. Let's say we want to test x = 1. In this case, we get 2(1)3 > -8(1)2. We must then conclude that for all x > 0, we have 2x3 > -8x2. Otherwise, there would have to exist another value of x > 0 such that 2x3 = -8x2. This is impossible though since the only x values that work are x = 0 and x = -4.
The other two intervals are very similar. Test an arbitrary value between -4 and 0, and before -4 and see if 2x3 < -8x2 or 2x3 > -8x2
nukeman said:
we have to do it without graphing it.
Mark44 and others gave the alternative ways of solving it. But I didn't mean to go get a graph plotter and do it but just make a general sketch of the graph, or was that what you meant? (no sketching or plotting)
