Polynomial splits over simple extension implies splitting field?
The discussion revolves around the relationship between polynomial splits over simple extensions and the implications for splitting fields. Participants explore the conditions under which a simple extension can be considered a splitting field, including the definitions and properties of splitting fields and roots of polynomials.
  • One participant proposes that if a polynomial ##p## splits over a simple extension ##\mathbb{K}=\mathbb{F}(\alpha)##, then ##\mathbb{K}## is the splitting field of ##p##.
  • Another participant questions how it can be concluded that ##\alpha \in \mathbb{L}##, the splitting field of ##p##, given that ##\mathbb{L}## must contain all roots of ##p##.
  • A different participant suggests a scenario where ##\mathbb{L}## contains roots that do not include ##\alpha## but are isomorphic to a set of roots that does include ##\alpha##, raising questions about the interpretation of containment between fields.
  • One participant acknowledges the critique regarding the need for rigor and suggests the use of an algebraic closure to clarify the relationship between the fields.
  • Another participant asserts that since a field cannot contain more roots than its degree, and given that ##\alpha## is a root in ##\mathbb{K}##, it must also be in ##\mathbb{L}## without needing to invoke an algebraic closure.
Participants express differing views on the necessity of including ##\alpha## in the splitting field ##\mathbb{L}## and the implications of isomorphism in the context of field containment. The discussion remains unresolved regarding the soundness of the initial argument and the conditions under which a simple extension can be a splitting field.
Participants highlight the importance of definitions and the potential need for rigorous treatment of algebraic closures in the discussion of splitting fields and roots of polynomials.
MostlyHarmless
This is a question that came about while I attempting to prove that a simple extension was a splitting field via mutual containment. This isn't actually the problem, however, it seems like the argument I'm using shouldn't be exclusive to my problem. Here is my attempt at convincing myself that the subject line is true:
Let ##p## be a polynomial over a base field ##\mathbb{F}##. Let ##\mathbb{K}=\mathbb{F}(\alpha)## where ##\alpha \not\in\mathbb{F}## and ##\alpha## is a root of p. Now, suppose ##p## splits over ##\mathbb{K}##. Then ##\mathbb{K}## is the splitting field of ##p##. (?)
Proof. Let ##\mathbb{L}## be the splitting field of ##p## over ##\mathbb{F}##. Then ##\mathbb{L} \subseteq \mathbb{K}## since ##p## splits over ##\mathbb{K}##. Now, ##\alpha \in \mathbb{L}##, but by definition ##\mathbb{K} =\mathbb{F}(\alpha)## is the smallest field containing ##\mathbb{F}## and ##\alpha##. So ##\mathbb{K} \subseteq \mathbb{L}##. So mutual containment is established and ##\mathbb{L} = \mathbb{K}##. //
Is this argument sound? It seems like if it were, this is something that might have been mentioned in our discussion of splitting fields.
How do you get that ##\alpha\in L##?
Since ##\alpha## is a root of f and ##\mathbb{L}## is the splitting field of f. ##\mathbb{L}## must contain all roots of f, basically by definition of splitting field.
I was thinking of the case where ##\mathbb{L}## contains a set of roots, none of which is ##\alpha##, but which is the isomorphic image of a set of roots containing ##\alpha##. I guess that's not a problem if we interpret ##\mathbb{L}## and ##\mathbb{K}## to refer to equivalence classes under isomorphism and the expression ##\mathbb{L}\subseteq\mathbb{K}## to mean for every element of the equivalence class ##\mathbb{L}## there is is an element of ##\mathbb{K}## of which it is a subset.
If we go that way, your whole argument appears sound to me.
That is a fair critique I suppose. If we wanted to be super rigorous we could fix an algebraic closure of ##\mathbb{F}## call it ##\mathbb{F}^*## with ##\mathbb{F} \subseteq \mathbb{K} \subseteq \mathbb{F}^*##.
But either way, while the argument is very short, it seems like a useful lemma that might be discussed at some point. As I find myself making the same argument over and over again. Particularly recently during the discussion of Galois theory.
a filed cannot contain more roots than the degree, so since alpha is contained in K and is a root, and since L is contained in K and contains a full set of roots, then that root alpha must be in L. no fancy algebraic closure choices needed, (although i also first thought of going that route.)
