Swamp Thing
- 1,076
- 848
- TL;DR
- My brand new phone got bricked. Could it be one of these things that I did?
My phone (Samsung, running Android Go) got bricked a day or two after purchase. The first sign of trouble was that the display wouldn't wake up from standby. I had to remove the battery and replace it in order to get it going again. When I did that, it got stuck displaying the logo and wouldn't continue starting.
I removed the battery once more and replaced it, and it restarted properly, only to hang up after a few minutes of use.
At this point, I decided to remove a micro SD card that I had installed previously (well before the problem started). Removing and replacing the battery got it working again for a while, but it ended up bricked shortly afterwards.
I tested the Micro SD card, which had seen several years of use in another device -- and I found that the card would no longer work.
I took the phone to the service center, and they have repaired it, so I'll be collecting it later today. I'd like to avoid doing anything that could have triggered the problem.
What could have gone wrong, apart from a random glitch? Which of the following is most likely?
[1] The memory card was marginally failing, and it triggered a glitch that corrupted the firmware
[2] Removing the battery when the phone froze on the logo, caused a firmware corruption
[3] A third party app that I had installed from play store, was not compatible with Android GoRegarding [2], what does one do to recover safely from a freeze-on-logo condition?
