Potential difference between the parallel metal plates
The problem involves two parallel metal plates that are initially 2mm apart and connected to a 9V battery. After removing the battery, the separation is increased to 1 cm, and the question is about determining the new potential difference between the plates.
  • Participants discuss whether the potential difference remains constant after the battery is removed and consider the implications of charge conservation and electric field behavior. There is also a mention of using capacitance to analyze the situation.
Participants are exploring various aspects of the problem, including the relationship between charge, potential difference, and capacitance. Some guidance has been offered regarding the conservation of charge and the implications of changing plate separation on capacitance and potential difference.
There is a lack of information regarding the area of the plates, which is noted as a constraint in the discussion. Participants are also considering the implications of the problem setup on the electrostatic principles involved.
jamesjenson
Two metal plates are placed in parallel, 2mm apart. They are then connected to a fully charged 9V battery. Without discharging the plates, the battery is removed, after which the separation between them is increased to 1 cm. What is the new potential difference between the parallel metal plates?
E=Vd E= Q/4ε∏r2
I have no clue whatsoever, the prof never even went over this, just a hint in the right direction would be apperaited
Ask yourself: with the battery removed, will the potential difference stay constant? Will the charge on each plate (and therefore electric field)?
There are several ways to find potential difference. If potential remains constant, use the one involving that. If electric field remains constant, use the one involving that instead.
Ok, so if there battery is removed then, and the plates don't touch anything, they would keep their charge, no? So the only change would be the distance between them?
Yes, they keep their charge. It might also help to remember [itex]E = \frac{\sigma}{\epsilon_0}[/itex]
ok, but doesn't {\sigma} mean Q/A ? and I don't have any info on the area of the plates here
The point is that the area of the plates doesn't change. So if both Q and A stay the same, so does sigma, and we know [itex]\epsilon_0[/itex] is a constant.
ahhh! Ok, I don't see why I didnt see that, thanks!
Can we use the concept of capacitance here in this example :
C = eA/d
and
C = Q/V
I think that as "d" would be increased 5 times then "C" would decrease by five times.
As C decreases by 5 times then (since charge "Q" on the plates is conserved) "V" would increase by five times .
Thus (new) V = 45 V
Does that not satisfy all the electrostatics principles ?
  • · Replies 28 ·
