Potential Energy and Total Energy Negative
Potential energy (PE) and total energy (E) can be either positive or negative due to their dependence on reference points, while kinetic energy (KE) is always positive. The equation for potential energy, PE = mgh, indicates that if the height (h) is measured from ground level (h = 0), then PE can be negative when below this reference. In atomic and orbital contexts, potential energy is often negative when measured from a reference point of infinity. Total energy can be negative when potential energy is negative, as expressed in the equation E = KE + PE.
  • Understanding of basic physics concepts, particularly energy types
  • Familiarity with the equations for kinetic energy (KE = 1/2mv^2) and potential energy (PE = mgh)
  • Knowledge of reference points in physics
  • Basic grasp of atomic structure and gravitational fields
  • Research the concept of reference points in gravitational potential energy
  • Explore the implications of negative potential energy in atomic physics
  • Study the relationship between kinetic energy and velocity in detail
  • Investigate the conservation of energy in closed systems
Students of physics, educators explaining energy concepts, and anyone interested in the principles of energy in mechanics and atomic structures.
Jordash
Explain why it is possible for potential energy and total energy to be either positive or negative, but kinetic energy is always positive
I'm thinking that Potential Energy and Total Energy can be opposite and take away from each other, so they would be negative to subtract, but not sure how to think this one through.
Potential energy is measured with respect to a reference point.
For example, in PE = mgh, the PE depends on the h and where it is measured from. If you take ground level to be h = 0, then you have negative PE as soon as you go down below the surface.
The potential energy of an electron in an atom and of a satellite in orbit is measured with a reference point of infinity, so these energies are always negative. Believe it or not, infinite distance is the simplest reference level, because it is the only level that is common to all atoms or planets.
Ok, that makes sense, what does it mean when it says Total Energy? I think it means
E=KE+PE
E=1/2mv^2+mgh
So Total Energy can be negative because Potential Energy can be negative, is that right?
Also, look at your equation for kinetic energy: (0.5)*(m)*(v^2) - can any of these variables be negative?
well velocity could be I guess but it's square so it will always be positive.
Exactly! So then, can Kinetic energy EVER be negative?
Now look at the equation for potential - what can be negative there, and can it make the whole value negative?
no never, thanks for the help!
No problem! Physics Rules!
  • · Replies 22 ·
