Potential energy and work by spring.
8 replies · 28K views · last reply
Crusaderking1
A 15.0 kg stone slides down a snow-covered hill (the figure ), leaving point A with a speed of 10.0 m/s. There is no friction on the hill between points A and B, but there is friction on the level ground at the bottom of the hill, between B and the wall. After entering the rough horizontal region, the stone travels 100m and then runs into a very long, light spring with force constant 2.50 N/m. The coefficients of kinetic and static friction between the stone and the horizontal ground are 0.20 and 0.80, respectively.
Here is the picture: http://session.masteringphysics.com/problemAsset/1260235/2/YF-07-34.jpg
A) What is the speed of the stone when it reaches point B?
B) How far will the stone compress the spring?
PE = mgh
KE = .5mv^2
spring = .5kx^2
A) I did this:
PE = (15.0)(9.80)(20.0) = 2943 J
KE= .5(15.0)(10.0)^2 = 750 J
2943+750 = 3693 J
3693 = .5(15.0)(v)^2-.5(15.0)(10.0)^2
v=19.80 m/s
B) work done by spring = .5(2.50)(x)^2 = 1.25x^2
work done by friction = (0.2)(15.0)(9.8)x = 29.4x
Using quadratic:
1.25x^2 + 29.43x - 3693 = 0
x= 43.84 or -67.38
x= only 43.84 meters.
Do these answers seem right? thanks!
A) I did this:
KE= .5(15.0)(10.0) = 750 J
2943+750 = 3693 J
v=19.80 m/s
You miss a square it the KE term: It has to be .5(15.0)(10.0)2
I do not understand what you mean with the second term when you calculate the velocity at B.
ehild
I do not understand what you mean with the second term when you calculate the velocity at B. ehild
yes, thanks. It should be .5(15.0)(10.0)^2 = 750 J.
Wouldn't the total energy = KE + PE, so 750 Joules+ 2943 joules be the total work at point B? Then set 3693 joules equal to .5mv^2-.5mvo^2, which game me 19.80 m/s.
So the total energy at B is 3693 J, what is the velocity there?
ehild
ehild
Oh ok. I think that I only need to set the joules equal to the final velocity, since the initial is 0.
In that case, velocity would equal 22.2 m/s.
Correct!
Now, question B. Before the stone reaches the spring, it slides 100 m on the rough ground. So it has lost a lot of energy when reaching the spring.
ehild
ehild said:
Correct!
ehild
thanks! I will try figure part B out now.
ok, I added work done by friction. I received (15.0)(9.8)(0.2)(100)cos180 = -2940 joules.
-2940 + 3693 joules = 653 joules.
Would the new quadratic equation be 1.25d^2 + 29.4d -653 = 0?
Crusaderking1 said:
t
it looks all right, but the red 6 has to be 7.
ehild
ehild
ah ok. good catch. Thanks a lot for the help!
