What is the power of a sound source placed on a tall radio tower?
The discussion centers on calculating the average power of a sound source located at the top of a 189.6m radio tower, emitting sound at a frequency of 740 Hz and an amplitude of 19.4 nm. The air density is 1.29 kg/m³, and sound travels at 343 m/s. The main formula for power involves the density of air, sound velocity, amplitude, and the area of the speaker, which remains unspecified in the problem. Participants express concern that the lack of the speaker's area makes the problem unsolvable, while also noting that sound intensity varies with distance from the source. The conversation highlights the assumption that the speaker can be treated as a point source for the purpose of this calculation.
nicholasH
A sound source is placed at the top of a tall (h = 189.6m) radio tower. The source has a frequency of 740 Hz and an amplitude of 19.4 nm at point A. The air surrounding the tower has a density of 1.29 kgm-3 and sound travels through it with a velocity of 343 ms-1. Point A is 13.5 m above the source. You may ignore any reflections of the sound from the ground.
Calculate the average power leaving the source.
P = (1/2)pAv(ws)^2
where p = density of air = 1.29
v = sound velocity = 343
s = maximum displacement (amplitude) = 19.4e-9
w = 2Pi*f = 2960*Pi
A = area of speaker
It seems that this question is unsolvable without being supplied with the area of the speaker. Unless the amplitude at Point A somehow depends upon this area, however I'm sure that it depends solely upon the size of the speakers vibrations, not the area of the surface causing them.
Any help would be greatly appreciated.
The intensity of a sound wave is given in units of power per area, so starting from your expression, you'd get
$$I = \frac PA = \frac 12 \rho v (\omega s)^2.$$ You're probably supposed to assume the speaker can be treated as a point source. How does the sound propagate away from the speaker and how does the intensity of sound vary with distance?
9K
9K
  • · Replies 20 ·
13K
