Power spectral density of a laser's frequency noise
  • Context: Graduate
  • Thread starter Thread starter Malamala
The discussion revolves around the concept of power spectral density (PSD) in the context of laser frequency noise, particularly focusing on the differences in PSD plots obtained through self-heterodyne measurements. Participants explore the implications of varying fiber lengths in these measurements and the resulting shapes of the spectra.
  • One participant expresses confusion about the differences in PSD plots obtained from self-heterodyne measurements, noting that one shows 1/f noise while the other shows a Lorentzian shape.
  • Another participant suggests that longer fiber lengths improve frequency resolution, allowing for better resolution of slowly varying phase noise.
  • There is a question about whether the different spectral shapes arise solely from the longer fiber delay and if the beta-line method remains applicable with longer fibers.
  • Some participants discuss the implications of the self-heterodyne measurement technique, noting that it down-converts phase noise to zero frequency, which can complicate the interpretation of results.
  • Concerns are raised about the practical outcomes of measuring PSD experimentally using different fiber lengths, questioning what one would observe in terms of noise characteristics.
  • One participant mentions that the first paper indicates that shorter fiber lengths limit the frequency range of the PSD, while longer fibers might provide more information but are not necessarily preferred by all researchers.
Participants express differing views on the advantages of using longer versus shorter fiber lengths for self-heterodyne measurements, with no consensus reached on which method is superior or why certain practices are favored in the field.
Participants note that the differences in spectral shapes and the implications of fiber length on measurements are not fully resolved, and there are assumptions about the relationship between fiber length and the information provided by the PSD that remain unexamined.
Malamala
Hello! I am a bit confused about what power spectral density (PSD) is in the context of a laser. In particular, I came across this paper. In Fig. 1 they show PSD vs frequency. As far as I understand, PSD is just the square of the FT spectrum of a laser frequency/phase as a function of time. Later in the paper (Fig. 2), they mention that a way to get a plot as in Fig. 1 is to make a self-heterodyne measurement. However, in other papers (and this was my understanding so far, too), doing a self heterodyne would give you a spectrum with a Lorentzian/Gaussian lineshape, from which you can directly get the linewidth of the laser (e.g. this paper, Fig. 2). My confusion is in the fact that the 2 plots appear to be obtained the same way (self-heterodyne method), they both show PSD vs frequency, yet they look so vastly different. The first one shows a 1/f noise followed by white noise at high frequencies, while the second one has a Lorentzian shape or some other weirder shape depending on the length difference between the 2 optical fibers.
Is the length difference the only difference between them, or am I missing something else? In the first paper they use 20 m difference, while in the second paper the fibers difference is on the order of 1 km. And if that is the case, I have a second question. It seems like the plot in the first paper gives you more information than the second one. The second one basically gives you just the laser linewidth, but the first one can be used to get the laser linewidth (e.g. using the beta-line method described there), but you can get further insight, too (e.g. what bandwidth would you need for a servo to suppress the 1/f noise). If that is the case, why are many people using a large fiber difference between the 2 arms for getting the laser linewidth (I know from experience, as everyone I talked to mentioned the second method, of using fibers of 1-10 km difference for linewidth measurements). What advantage does the second method gives, as in my naive understanding the first method is better from all points of view (more info provided about the laser and cheaper, shorter optical fibers). Thank you!
I guess, the longer fibre, gives a longer time delay between samples, so the frequency resolution will be improved. That should better resolve phase noise that varies more slowly, that is, closer to the centre frequency of the laser. Very long fibres should give the Gaussian profile of the line.
But I guess my main question is: does the different shape come only from the longer delay? And if I make the fiber longer, would that beta-line method still work at all, given that the spectrum shape would be completely different?
What exactly do you mean by "phase noise that varies more slowly, that is, closer to the centre frequency of the laser"? Isn't slowly varying phase noise close to f = 0 (i.e. to the very left of x-axis)?
The longer line makes more information available, so the PSD becomes more realistic.
"A self-heterodyne measurement" beats the signal against a delayed version of the signal. That is sensitive to phase noise and down-converts it to zero frequency. But the self-heterodyne has also down-converted the line to zero frequency, which tends to saturate that channel, and to jump around since low frequencies are present. To eliminate that instability, the light was first modulated with 100 MHz, so there is also a component that falls into the spectrum analyser centred on 100 MHz. The more stable spectrum analysed near 100 MHz is digitised by the SA, and scaled to convert it to the PSD.
Uhh... I am still confused... if i measure the PSD experimentally using the self-heterodyne method, what would I see? Would I see 1/f + white noise, as in the first paper, or the Lorentzian shape as in the second paper?
Also, it's still not clear to me how the length of the line matters i.e. what do you mean by more information? The first paper mentions that the length matters only in going to higher frequencies. For 20 m, they can get the PSD only up 10 MHz. However, going higher than that is usually not needed, as at these frequency the lasers have white noise at a known level. Also, based on the first paper, TOPTICA uses that method (of 20 m difference) to define the linewidth of their lasers. However, TOPTICA is one of the best laser companies in the world, so if using a longer fiber would give a much better linewidth measurement, why are they using this one (buying few km of fiber is a few thousand dollars, which is definitely not an issue for TOPTICA)? There has to be a reason for using this method over the other one (involving a bigger difference in fiber lengths).
Your question confuses me because both show essentially the same data. Baluncore already explained it well, but just to add a simplified summary:
You use the self-heterodyning to get the noise you are interested in to a frequency range where little other noise sources are. So (oversimplifying - the details are slightly more complicated) by modulating at 100 MHz you will find the noise component for 1 kHz shifted to a signal frequency of 100.001 MHz, the noise component for 10 kHz shifted to a signal frequency of 100.01 MHz and the noise component for 1 MHz shifted to 101 Mhz.
When you take figure 2, shift the x-axis by 100 MHz and plot everything on a log axis, you will end up with something similar to figure 1.
The good thing is that only noise that is actually originating from the laser is shifted to higher frequencies, while, e.g., mechanical noise originating from vibrations of the table is not.
I wonder if some of your confusion is caused by the vastly different scales in the two plots, for both the x- and y-axes.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
