Precalculus Algebraic Inequality
The problem involves solving the algebraic inequality -3 < (1/X) ≤ 1, which requires consideration of the behavior of the function (1/X) across different ranges of X.
  • Participants discuss the necessity of considering different cases based on the sign of X, specifically X > 0 and X < 0. There are questions about the correctness of initial attempts and the implications of multiplying by negative numbers on the inequalities.
Participants are actively engaging with each other's attempts, pointing out potential errors and clarifying the need for multiple cases. Some guidance has been offered regarding the correct handling of inequalities when multiplying or dividing by negative values.
There is an emphasis on the requirement to find the intersection of solutions from different cases, as well as the importance of ensuring that all steps adhere to the rules of inequality manipulation.
bcheero
-3<(1/X)≤ 1
Solve.
Here's my attempt at it:
(1/X)≤1 and (1/X)> -3
X≥ 1 and X> (-1/3)
Am I doing something wrong here? Is this the complete solution? Looking at my answer, is there more that I should I add?
Welcome to PF
For each inequality, you have to consider two different cases: X > 0 or X < 0. You also have to be careful. When you multiply both sides by a negative number, the sign of the inequality flips. Therefore, if X < 0, one of your solutions is wrong. Let me show you. We start with:
1/X > -3
If you just multiply both sides by X and then divide both sides by -3 without ever flipping the inequality sign, you may get the wrong answer, depending on whether X is positive or negative. Consider, for example, X = -1/4. It satisfies your solution that X > -1/3. However, it means that 1/X = -4, which is NOT greater than -3. So in this case, your solution is wrong.
You have a very responsive community here!
So if I fix the error that you pointed out, will my solution be correct?
Did you read what I posted? For each of the two inequalities, you have to consider two different cases: X > 0 and X < 0. Therefore you're doing four computations. Each case will in general lead to a different solution (meaning a different range of allowable X values). So your solution is incomplete.
EDIT: To clarify, your final solution will then be the intersection of these four sets (allowed x ranges)
I considered your scenarios and this is what I have:
X ≥ 1 , X< -1/3, and -1/3 <X<0
I think you're close, but that's not quite right. Since you've clearly given it a number of attempts let me run through it for you. Let me know if you have any questions:
CASE 1: X > 0
As you know, our original inequality is actually two separate ones:
i) 1/X ≤ 1
ii) -3 < 1/X
To solve (i), I'm going to multiply both sides by X. Since X is positive, I don't have to flip any signs, and I end up with:
X ≥ 1
To solve (ii), I'm going to multiply both sides by X:
-3X < 1
then I'm going to divide both sides by -3, which requires a sign flip, since -3 is negative:
X > -1/3
Since the above inequality is satisfied by ANY X > 0, this result doesn't actually provide any useful constraint. So the result is:
Solution for CASE 1: X ≥ 1
CASE 2: X < 0
To solve inequality (i) for X, we have to multiply both sides by X, which requires a sign flip since X is negative:
X ≤ 1
Since this result is satisfied by ANY X < 0, it does not provide a useful constraint. Solving inequality (ii), we have to first multiply both sides by X, and then divide both sides by -3. Since we multiply by TWO negative numbers, we have to flip the inequality sign twice, which is the same as not flipping it at all:
X < -1/3
Solution for CASE 2: X < -1/3
The final solution is therefore the union of the solutions for the two cases:
X ≥ 1 OR X < -1/3
