Preparing 40mM TES pH 7.4 - Calculating A-/HA
  • Thread starter Thread starter vande060
6 replies · 3K views
vande060
prepare 40mM TES buffer pH 7.4
prepare 100mls of it
mw TES = 229.25
pka = 7.5
ph = pka +log(A-/HA)
My problem is that I don't know what the MW of the acid or base is for this buffer. Is the given MW the acid, and I subract a proton weight for the base or something? I can do the calculation though:
7.4 = 7.5 +log(A-/HA)
-.1 = log(A-/HA)
A-/HA = .79
56% base
44% acid
.56* 40mM * MW of base *.1L = moles of base
.44*40mM *MW of acid *.1L = moles of acid
So how should I figure out the MW of acid and base?
http://en.wikipedia.org/wiki/TES_(buffer )
Given molar mass refers to the acid.
Thank you,
Ok, that's kind of what I thought. So the acid MW is 229.25, and the base would be (229.25 - 1.008) is that correct?
You don't need molar mass of the conjugate base. Use enough acid to prepare 40 mM solution, neutralize it with any strong base.
so I would go:
229.25g/mol * .04moles/liter *.1L = .917g TES added
then to calulate strong base needed to convert 56% of acid to base
.04moles/liter *.1L = .004 moles TES * .56 = .00224 moles of strong base needed
Check your math. If more than half of the acid is converted to base pH is higher than pKa.
But in general you are on the right track.
whoops it should be 44% converted to base
