Preparing AlCl3 (Hexahydrate) 100ml
  • Thread starter Thread starter guyat35
5 replies · 33K views · last reply
guyat35
Is it possible to prepare Aluminum chloride (hexahydrate) solution(15%) from Aluminum chloride powder (ANHYDROUS)? I need it only in small quentities ie. 100ml.
Please help.
Chemistry news on Phys.org
Just add water, stirr, a bit of heat would help but not too much.
Seriously water plus AlCl3 is a very powerful almost explosive reaction, lots of heat comes out of it. So you will have to add the water carefully. A simple method is take your AlCl3 and leave it out in the open for a few days, it will absorb ambient humidity and then adding more water will be by far less explosive. Or add water with a steam bath. Easy to build, take a pot with a lid add hot water in it, and place your AlCl3 in a cup so that it does not get wet or floats, close the lid and wait for a bit.
... or just leave it out in the moist air. Takes longer. Not as exciting.
Thanks for the help. I think adding water to AlCl3 will give me Aluminum chloride (hexahydrate) in white crystal form. But how can make a 15% solution of Aluminum chloride (hexahydrate)? Adding Alcohol? Is it the right way? please help
Alcohol is for later... evenings in pubs.
All you need to do is (assuming that the 15% is in mass percentage) add 15g of AlCl3hexa to 85g of water. The result will be 15%, but I cannot guarantee that you will end up with 100ml, rather close to that anyway.
If the solution should be in alcohol, there should be some mention of that in the formula. The same goes with the percentage for alcohol 85 g, and still no telling how close the volume will be.
Please help.
To get AlCl3*6H2O from AlCl3 it's better if you use dilute HCl, instead of water.
