Bismuth Crystals
  • Thread starter Thread starter Hornbein
17 replies · 4K views · last reply
Hornbein
Very unusual looking.
Chemistry news on Phys.org
Yeah, often found at mineral shows, they are lab grown, they dont normally grow like that in the ground
I have a couple of pieces like that here in my collection, if I remember, I will do a photo
I have a couple of peices like that here in my collection, if I remember, I will do a photo
It has both metallic and crystalline forms. Does anything else or is this unique?
Metallic and crystalline are not mutually exclusive :wink:
Almost all metals have crystalline forms
Dave
Dave
Aha. So it's the size of the crystals then. Do any metals aside from Bismuth so easily form large crystals like that.
Huh, I thought metals had to be made of the elements, not compounds. I thought metals had to be flexible. The dictionaries say otherwise. They say the only requirements are that it be hard and conduct electricity and heat. There's no arguing with dictionaries, but in this case I believe they deviate from actual usage. If I were to use the word in this way I would be misunderstood.
I also learned that a "metalled road" is a road covered with crushed stone.
I always thought that steel, bronze, and brass were metals. But that's the problem with vernacular language, it all depends on how you learned it. IDK.
But "flexible"? OK, whatever.
Steel bronze and brass are alloys entirely composed of the elements (or so I believe anyway). No rule against mixing them.
Perhaps you misspoke? Isn't that everything?
Also, I don't think the Carbon in Steel is a metal, but I'm bad at Chemistry and Carbon is weird.
Anyway my point is that common language fails in science when we start splitting hairs.
Anyway Gallium might be a good candidate. Like Bismuth it isn't toxic or very reactive, and has a low melting point.
If I had written "composed entirely of an element" then I would have misspoken.
Carbon is an element so I say it's included. It's not a metal but that doesn't prevent it from being included in a metal.
I am puzzled by why the dictionary definition differs so much from common usage. Maybe chemists use that definition. But dictionaries make note of specialized usages.
no, crystal size is irrelevent.
a crystal is a crystal regardless of it is 1mm or 1m in size
and it also doesnt matter if it is a metal or a non-metal element
This has become a very strange thread. Perhaps I'm misunderstanding something.
Hi Dave ... it's all because Hornbein didnt seem to realise that most metals have crystal forms
as I stated earlier. He appeared to think that the crystal habit of a metal was uncommon and that
a metallic substance ( pure element or mineral compound) couldnt be both a metal and a crystal.
The confusion comes with not realising that a crystal is just a form/habit of elements or minerals
Galena, PbS - Lead Sulphide - has a cubic crystal habit
But Fluorite - CaF2 - totally non-metallic, also has a Cubic crystal habit
Neither of those 2 are from my collection .... this next one is
Pyrite - FeS2 -Iron Sulphide - from my collection, also has a Cubic crystal habit
With only a quick look, Bismuth is the only native element that I found with a cubic crystal habit,
there may be other ones?
But there are many different crystal habits for all native elements and for minerals
A mineral, is just a combination of native elements as shown in the examples above
cheers
Dave
It appears one may grow large crystals of any of the metallic elements. This seldom occurs in nature and I suppose it isn't easy dealing with the necessary high temperatures. Iron crystals may sometimes be found in meteorites.
Sure enough, it's easy to make big gallium crystals.
I liked the theory that the celebrated 'Oumuamua asteroid is an intergalactic crystal of hydrogen. But such would not have survived solar radiation.
Steel, bronze and brass are metals and alloys. Alloys are just mixtures of metals. Depending on manufacturing method, there may be impurities of C, N, O, P and S, as well as others.
Pure metals are much more expensive. With pure metals, one would want to melt under vacuum to avoid pickup of N and O from the air, especially for reactive metals.
One can form interesting crystal structures by freezing metal vapors on a 'cold' mandrel/substrate (physical vapor deposition).
Colored surfaces due to different oxide layers is often performed with anodizing certain metals like Ti, Zr, Nb, or stainless steels. I've observed this in person.
Ref: https://en.wikipedia.org/wiki/Chemical_coloring_of_metals
From Google AI regarding Bi, "Bismuth crystallizes into a distinct rhombohedral structure (A7-type) belonging to the trigonal crystal system with the ##R\bar{3}m## space group. Its unique, stair-stepped "hopper" shape occurs because its outer edges grow faster than the inner faces as the metal rapidly solidifies and expands."
Bi has a relatively low melting point: 544.7 K (271.5 °C, 520.7 °F), which makes it easier to melt and form crystals.
Element is the general term for each unique chemical species listed in the periodic table. Hydrogen, Helium, Lithium, Beryllium, Boron, Carbon, Nitrogen, Oxygen, Flourine, Neon, are the first 10 elements by atomic number (Z); the atomic number signifies the number of protons in the nucleus and the number of electrons surrounding the nucleus of atom, when it is electrically neutral. A loss of electrons yields a positive ion, while a gain of electrons yields a negative ion.
One can produce 'pure' metals, but that may mean 99.5%, 99.9%, 99.99%, . . . . The higher the level of purity, the more expensive.
Group 1 of the periodic table Li, Na, K, Rb, Cs, Fr are alkali metals. Note hydrogen (a diatomic gas) is not ordinarily metal unless it is cooled and compressed; one can make metallic hydrogen.
Group 2 in the periodic table, Be, Mg, Ca, Sr, Ba, Ra are alkali(ne) earth metals.
Groups 3-12 are transition metals.
Starting with Group 13, things get interesting regarding classification. Boron is considered a metalloid, while Al, Ga, In, and Tl are considered metals. Metalloids are elements with properties intermediate between metals and nonmetals.
Carbon is a nonmetal, while Si, Ge are considered metalloids (semiconductors) and Sn, Pb are metals.
This may help: https://periodictableguide.com/metalloids-located-on-the-periodic-table/
https://en.wikipedia.org/wiki/Metalloid
On a standard periodic table, metalloid elements form a diagonal, stair-step line separating the metals on the left from the nonmetals on the right. Depending on the classification system used, elements like Polonium (Po) and Astatine (At) are also sometimes classified as metalloids.
Most metals are not used in their pure form, but rather are alloyed; some elements are used in pure form, e.g., alkali metals like Li, Na and even Pb, for liquid metal cooled systems, but often Na is alloyed with K, and Pb is alloyed with Bi. Usually, the alloy is determined by the mixture with the lowest melting point. Of course, Au and Ag are used in their pure form as in bar form (bullion), but in more common usage such as jewelry, Au or Ag may be alloyed with aluminum, silicon, nickel, copper, cadmium, zinc, tin, . . . .
Every metal exists in crystalline form – even mercury, at a sufficiently low temperature. However, cast metal typically has such fine crystals compacted into a single mass that they are invisible. In the case of bismuth, the element crystallizes relatively easily as skeletal crystals. This is due to its low melting point, which means it doesn't require a smelter to melt it, and readily available thermal insulation is sufficient to cool it slowly, allowing the crystals to grow larger. I believe the phenomenon of volume expansion during solidification also helps – crystal seeds float within the mass of molten metal and can be picked out.
The color of a bismuth crystal, however, is the result of a thin layer of transparent oxide forming on the surface, which creates colors through interference.
