Preserving breast milk for jewelry
  • Thread starter Thread starter Ty2828
The discussion revolves around the preservation of breast milk for use in jewelry making, specifically focusing on the appropriate chemical preservatives and methods to ensure the milk remains stable and visually appealing over time. Participants explore various techniques and materials, including heating, drying, and mixing with resins.
  • Experimental/applied
  • One participant seeks advice on using optiphen and sodium benzoate as preservatives for breast milk intended for jewelry, expressing uncertainty about their effectiveness.
  • Another participant highlights the composition of milk, noting that lipid droplets contribute to its optical properties, which may be lost during the drying process.
  • A participant mentions that pasteurization does not completely sterilize milk, suggesting that additional measures may be needed to eliminate bacteria.
  • Discussion includes the potential use of plaster of Paris to chemically fix the water fraction in the milk, which may help prevent bacterial growth when mixed with resin.
  • There are suggestions to experiment with the amounts of plaster and optiphen to determine the best combination for preservation.
  • One participant shares their experience with embedding biological specimens in resin, noting the importance of the fixation and dehydration processes.
  • Another participant mentions that sodium benzoate works best at an acidic pH, which may not be applicable in this case since the final product will be dry.
  • There is a suggestion to use cow's milk for experimentation before applying the method to breast milk.
  • Some participants inquire about the outcomes of mixing plaster of Paris with breast milk and whether it affects the color of the final product.
  • A participant references the historical use of milk in tempera paints and its relevance to jewelry decoration.
Participants express varying opinions on the best methods and materials for preserving breast milk, with no clear consensus on the most effective approach. Some participants agree on the potential of using plaster of Paris, while others raise concerns about the implications of removing lipids and the optical properties of the milk.
The discussion includes uncertainties regarding the chemical interactions between milk components and resin, as well as the effectiveness of proposed preservatives under specific conditions. There are also unresolved questions about the optimal ratios of materials to use in the preservation process.
Individuals interested in DIY jewelry making, particularly those exploring unconventional materials, as well as those curious about the preservation of organic substances in resin applications.
Ty2828
TL;DR
I’m looking for help to find the right preservatives for preserving breast milk in order to make jewelry with resin.
Hi everyone! My wife and I want to make breast milk jewelry but I’m having issues finding the right preservatives and amounts to use. We will be heating approx 5ml of milk and need a chemical preservative to mix in order to keep the milk from turning bad after months/years in the resin. The idea is to heat the milk with the chemicals until it’s a paste then spread it on wax paper. After it completely dries/(100% free of moisture )the product will be crushed into powder and mixed with the resin to make jewelry. I have optiphen and sodium benzoate. Would these be helpful? I’m no chemistry pro so just looking for opinions! Thanks
Chemistry news on Phys.org
this project is not fully clear to me.
Components of the milk will be lipids droplets as a part of the emulsion that the milk fluid is.
In the milk liquid, the lipid droplets will be separated by aqueous (water-like) fluid. These little drops have optical properties that give milk some of its look. This will probably be lost when dried down.
Is it your intent to get rid of the lipids also. Not sure how well the lipids will mix with the resin.
Hi, thanks for the response! Yes I want to completely eliminate all fluid/ anything that can go bad from the breast milk! Our goal is to preserve the milk into a dry powder form that will not mold/turn colors in the future. (We want the powdered milk to remain a white/off white color to be appealing to the eyes) There’s some others online that have discovered a way to preserve it through the pasteurization process that I believe eliminates the bacteria, that would cause it to go bad eventually (unfortunately they will not share their processes) During this they add a mixture of powdered chemicals that help to preserve it. I’m comfortable working with resin and the jewelry making process, I just need assistance with what chemicals would be best to achieve the preservation of the milk.
The only videos online are of the DIY kit nature and do not tell what the included preservation compound is made of. I’ll attach the link so you can better see what I’m trying to accomplish.
thanks!
Well that was different.
I have never heard of this before.
What I have done is fix, dehydrate and clear biological specimens and then embedded them in resin. This is done with chemicals that can be toxic if not handled properly.
This seems different.
It would be very useful to know what the secret powder is and does. Is does not seem to be any fix that I have heard of. There also seems to be a lot of it, perhaps more than the milk it was added to.
Pasturization does not completely sterilize the milk. It merely knocks down the numbers of active bacteria.
The powder may kill microbes. The resin may have similar properties.
I the process I mentioned above for biological specimens, the fixation process would kill everything and the dehydration process and clearing would remove all the lipids as well as making sure everything was dead.
Its not clear to me what is happening with the lipids (fats).
Small lipid droplets may make an emulsion with the resin (as they do in milk) which might preserve some of the milk's optical properties. These properties are in part based on light interacting differently with the lipid droplets and whatever is surrounding them (watery milk fluid or? resin).
Water will react with most resins so the water fraction of the fluid must be “fixed” in a chemical manner. This can be easily done by adding plaster of paris (the hemihydrate of calcium sulfate) and allowing it to harden. The result of this reaction is the dihydrate of calcium sulfate. This is simply gypsum powder like you would find in “desert rose.” It helps that the plaster is a brilliant white just like milk.
The instructions call for grinding the hardened (they refer to it as dry) plaster into a powder and suspending that into the resin. Drying something like this will prevent bacterial growth if kept sealed from atmospheric moisture... like maybe suspending it into some epoxy. The white of gypsum will stay that way for the ages! The resin will darken long before the remaining proteins and fats will cause any problem.
Ty2828 said:
Summary:: I’m looking for help to find the right preservatives for preserving breast milk...
Sodium benzoate works best at an acidic pH but your product will be dry so that’s not really a solution for you. The optiphen is a good choice. Its a mixture of 2-phenoxy ethanol and 1,2-dihydroxyoctane. The smallest and simplest of good old detergents these two!
Thanks for the great information! So just to be sure I am clear on what to do... I should simply add “plaster of Paris” to the raw breast milk while heating it in the double boiler. This should turn it into the plaster that I can then crush into the powder after it’s dry correct? Is there any need for the optiphen still?
Yes, exactly. How much of the plaster to add and how much optiphen will be your experiment. Use cow’s milk until you are satisfied with it.
If it sets too slowly, add an accelerator.
https://www.usg.com/content/usgcom/.../gypsum-plaster-accelerator.160216.html#!back
If it sets too quickly, try a retarder.
https://www.usg.com/content/usgcom/en/products/walls/drywall/plasters/gypsum-plaster-retarder.html
borax is a good set retarder for plaster and it has antifungal properties as well. Two-fer!
did mixing the plaster of Paris and raw breast milk work? Did the plaster alter the natural color at all?
Hallo, ich wollte fragen, ob der Versuch mit dem Gips bereits erledigt wurde?
.<mentor allows this post to remain the user now knows not to use German:
Hello, I wanted to ask if the plaster trial has already been done?
I have no experience using milk for jewelry, but milk in the form of casein is a common ingredient in tempera painting. Tempera paints with various additives have historically been used to decorate jewelry. For your info...
I believe the reason Elmer's glue is made by Borden's (a dairy company) is that it used to be casein glue made from milk. I think it was just acid-coagulated milk with some neutralizing base added to the coagulant. It will dry nicely I would bet. Google casein glue and someone will show you!
Now it is polyvinyl alcohol made from hydrolyzing polyvinylacetate. It is referred to as a PVA glue.
Casein (milk & lime == milk paint) painted designs on Egyptian furniture from the Middle Kingdom - 3500 years ago, are still in decent shape. I think natron (Sodium carbonate decahydrate) was used as the liming agent.
From metmuseum.org:
Hi, I'm very curious if you have found any way to successfully use breast milk into resin jewelry, without discoloration.
I would really like to try this myself, but there is no greater secret on the internet, than the method for preserving breastmilk for resin. Nobody will help me.
So maybe you can tell me your experiences?
My experience? It’s waaay too diffucult to get breast milk for me these days! Try milk and follow my advice earlier in the thread...
I found this DIY video on it and secret may be there. I suspect there is an additive that maintains the color or they paint the inside of the resin chamber a pearly white color.
I assume human breast milk, which has much more fat than cow's milk. A common resin is styrene (I used to build surfboards) and pretty much anything soluble in toluene, like triglycerols (natural fats), dissolves. A small amount of formaldehyde will stabilize the milk proteins. Styrene is toxic to bacteria. Styrene polymer excludes air helping preserve milk. Ambient ultraviolet will yellow plastic and maybe milk, so some UV absorber like sunscreen will stop that, but may interfere with hardening the resin. There is polyester resin liquid with hardner (cross linker) which is clear. Most ofthe others I've used were thermosetting, probably avoid cooking the milk. (Wax is translucent and easy to work with, perhaps.) I've been meaning to do more with natural resins example Amber which has been fossilized for 100,000,000 years. Latex is opaque but white like milk. Walmart has clear epoxy resin. I like the Tempera idea, dry the milk make Tempera then paint a baby picture? Murals in Medieval Italy painted with egg yolks and tempera are still vivid, but the plaster under them is crumbling.
Hi Tyler, I was hoping you could tell me if the plaster of paris and optiphen worked for preserving breastmilk.
Calling @Ty2828.
@paulamc you might not get a timely response since the member last visited our site 9 months ago.
Y
jedishrfu said:
Calling @Ty2828.
Yep it works
Did anyone get results? Pls share
And where can we find those chemicals?
It’s something that you will have to experiment with. No DNA artist will give you their formula and where to buy the items.
it takes us a lot of years to perfect our methods and don’t want backyard artists coming along to under cut us and or methods. Do some research and some experimenting
It takes 6-12 months minimum to see if any of our methods work and wait for any yellowing to occur.
There are ready made powders available on the market
Sorry I have not been online in a while to get back with everyone. Here is what I found back when I tried this... This method creates a powder but it does not have the breast milk jewelry look you see with professional artist. Unsurprisingly, it pretty much looks like powdered plaster in your jewelry. Would not recommend for breast milk jewelry personally as it comes out uniformly dull in every case. I tried several ways to no avail and eventually gave up and purchased a kit online.
Thank you for your reply, i am in experimenting process. I have a gold and silver jewelry studio on my own. Once i’ve done with experimenting, i will be doing any kind of design. I totally understand that you don't want to share your secrets, but this forum/ platform is for sharing information, not to sneak , read new ideas and say i won't share mine.
hi folks, once i’ve done with experimenting i will share which products i use with measures. I just need few months to share here . Wait for it :)
yes a plaster is not a good idea. It failed. I will let you know the exact chemical preservatives like the mix kit you bought.Let me watch results of different mixtures for few more months and i will share. Take care
Titanium dioxide powder can be used to brighten if it looks dull. It might help to classify the ground powder through a 325-mesh strainer.
On the resin side, HALS (hindered amine light stabilizer) can be used to prevent yellowing.
UV stabilizers can help as well but be sure to include HALS as well. Maybe a product with both?
Want pearlescent? Try this too! Add the titanium and/or pearl after grinding and classification.
I have been experimenting for over a year with so many different types of chemicals and the longest time a pendant has gone without yellowing is 9 months which I used food preservation powder for (sodium propionate to be specific). Please let me know how your process is going as I’m at my wits end here. All I want to do is preserve some breastmilk into jewellery for myself and a few ladies from my breastfeeding group I’m apart of. I’m so dedicated haha
  • · Replies 19 ·
9K
