Pressure inside a balloon with surface tension
  • Thread starter Thread starter charlie05
    Balloon Vacuum
26 replies · 3K views · last reply
charlie05
Balloon in vacuum, radius R0 = 5,0 cm, surface tension σ = 25 N/m.
a/ the pressure in the balloon p in,0 by radius R0………. pin,0 = ?
b/ relation to the pressure inside the balloon pin, depending on its radius R…?
c/relation to the pressure inside the balloon pin , depending on the pressure outside the balloon pout and on its radius R, surface tension is σ…….?
a/ pin,0=4σ/R0 = 4.25/0,05 = 2kPa
b/ pin = 4σ/R
c/ pin = pout + 4σ/R
in B/ I have to use pressure p in 0...
p in = 4σ/R ...R = R0 + ΔR = R0 + ( R-R0)...p in = 4σ/R0 + ( R-R0)
That looks wrong, no matter how I interpret the notation, and I don't see how you got it. In particular, it is undefined for the easiest case of R=R0.
Why do you want to change a correct answer?
Because I have to find dependence p in on p in 0 : Find the equation for the pressure p in inside the balloon, depending on the radius R, where
at radius R 0 is pressure p in 0
That's not what you write in post 1.
Yes, it's true, I did not read the assignment to the end :-( I am sorrry...
Your notation is hard to interpret, but I think you are saying:
With zero external pressure, the radius is R0 and the internal pressure is pin0.
With some unknown external pressure the radius is R; what is the internal pressure, pin, now?
If that is right, write out the equation for each of the two circumstances. Please use subscripts, as I have, to make the notation clearer. Use the X2 button above the text entry box.
b/ Find the equation for the pressure p in inside the balloon, depending on the radius R, where
Yes, that agrees with my interpretation. So what two equations can you write, one for the zero external pressure case and one for the general case?
in vacuum : ...pin = 4σ/R...for R0 ...pin0 = 4σ/R0
p in = 4σ/R ...R = R0 + ΔR = R0 + ( R-R0)...p in = 4σ/ (R0 + ( R-R0))
- But here now I can not express pin0
for the general case: pin = pout + 4σ/R
It's all the same balloon and contents. What does not vary as the external pressure changes?
pin0V0=pinV
pin = pin0*V0 / V = pin0 * (V0 / V ) = pin0 * (R03 / R3 ) ...?
charlie05 said:
super..thanks very much :-)
Ok, but what is your answer to the question, i.e. as an equation for pin in terms of pout, R and σ?
charlie05 said:
oh yes...pin = pout + 4σ/R...?
Sorry, my mistake... I meant the question posed in your post #7, where you need to find pin as a function of R, R0 and pin 0.
