MHB Prime numbers vs consecutive natural numbers.
All odd numbers can be expressed as the sum of consecutive natural numbers, while prime numbers (except for 2) can only be represented as the sum of two consecutive natural numbers. The sum of k consecutive natural numbers results in specific modular conditions, limiting viable candidates for k to 1 or 2. This leads to the conclusion that odd primes can be expressed as sums of two consecutive numbers, such as 7 = 3 + 4. The discussion emphasizes the unique property of prime numbers in relation to sums of consecutive natural numbers.
mente oscura
An easy question.
All "odd" number can be expressed as a sum of consecutive natural numbers.
Example:
35=17+18
35=5+6+7+8+9
35=2+3+4+5+6+7+8Question:
Demonstrate that prime numbers (except for the "2"), can only be expressed as the sum of two consecutive natural numbers.
Mathematics news on Phys.org
Re: prime numbers vs consecutive natural numbers.
Elementary. Sum of $k$ consecutive natural numbers is either $0 \pmod{k}$ or $0 \pmod{k/2}$ so the only plausible candidates are $k = 1$ and $k = 2$ which is easy to verify for odd primes.
mathbalarka said:
Sum of $k$ consecutive natural numbers is $0 \pmod{k}$ so the only plausible candidate is $k = 1$ which is easy to verify for odd primes.
7=3+4 \rightarrow{} k=2
Look at it again.
the question should be
Demonstrate that only prime numbers (except for the "2"), can be expressed as the sum of two consecutive natural numbers only.
let the number of numbers be n and 1st number a+1
then sum of numbers= an + n(n+1)/2
it is integer
if n is odd (n+1)/2 is integer so it is divsible by n
if n is even an and n(n+1)/2 is divisible by n/2
so if n > 2 and odd it is not prime as divsible by n
if n > 2 and even it is divisible by n/2(which is >= 2) so not prime
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
