Principal normal line to helix is normal to z axis
The problem involves demonstrating that the lines containing the unit normal vector n(s) and passing through the curve a(s) intersect the z-axis at a constant angle of π/2. The curve is defined as a helix, and participants are exploring the geometric relationships between the normal vector and the z-axis.
  • Participants discuss the formulation of the line L(t) and its relationship to the normal vector n(s) and the curve a(s). Questions arise regarding the angle between L(t) and the z-axis, particularly in relation to the dot product and the implications of translation by a(s).
Some participants are questioning the geometric interpretation of direction and the implications of the dot product in determining orthogonality. There is an ongoing exploration of whether the line L(t) intersects the z-axis, with some guidance provided on visualizing the helix and the normal vector's role.
Participants note the challenge of understanding the relationship between the translated line L(t) and its direction, particularly in the context of the z-axis. The discussion reflects a need for clarity on the definitions and properties of the vectors involved.
faradayslaw
DoCarmo Section 1.5 problem 1 part d. Show that the lines containing n(s) and passing through a(s) [a is the curve, and n(s) is the unit normal vector] meet the z axis under a constant angle of pi/2.
Helix: a(s) = (a cos(s/c_, a sin(s/c), b*s/c), so I computed n(s) = (cos(s/c),sin(s/c),0).
I think the principal normal containing n(s) and a(s) is : L(t) = (t-s)*n(s) + a(s). THis is because L'(t) = n(s), and L(s) = a(s), but when I try to show d/dt ( L(t) . z/Norm(L(t))) = Cos(theta) =0, I keep getting that it is not zero, due to the z-component of a(s), and the norm of L(t), which I compute to be ((Norm a)^2+(t-s)^2)^0.5, by orthogonality of n(s) and a(s).
Is there something I am donig wrong?
Thanks,
Thanks,
Since the z axis is in the direction of ##k=\langle 0,0,1\rangle##, isn't it obvious by the dot product with n(s) that they are perpendicular? That only leaves the question of whether the line L(t) actually hits the z axis. Can you find a t value for which ##L(t) = \langle 0,0,k\rangle## for some k, no matter what s is?
It's obvious to me that n(s) is perpendicular to z-axis, but I guess I don't really understand the following: The line L(t) must be in the direction of the vector n(s), but when we take the dot of L(t) with e_3 (the third basis vector in the canonical basis for R^3), we don't get 0 since the line is translated by the vector a(s0).
So: how is the line L(t) actually in the direction of n(s) if L(t) . e_3 =/= 0, but n(s). e_3 =0? I guess I don't understand the term "direction" well enough, since the angle between L(t) and z axis is precisely ArcCos(L(t).e_3/Norm(L(t)))?
Thanks
That makes no sense. a vector "translated" is still the same vector.
Thanks
L(t) is the position vector from the origin to the point on the line and it isn't perpendicular to the z axis. L(t) is the sum of two vectors: from the orgin to a(s) then from a(s) in a direction perpendicular to the z axis, which is given by n(s). The whole point of the problem is that if you go from a point on the curve in the direction of n(s) it will hit the z axis. It might help you to draw a picture of a helix going around the z axis. Pick a point on the helix an draw a position vector to that point then a line from that point perpendicularly towards the z axis. L(t) is a vector from the origin to a point on that line which varies along that line as t changes.
This clarifies it! Thank You !
