Probability density function of Z given Z < 1, where Z = X + Y
2 replies · 2K views
Legendre
Probability Mass Function of { Z | Z < 1 }, "Z given Z is less than 1"
Given Z = X + Y.
Find the probability density function of Z|Z < 1.
N.A.
f(z) = P(Z=z|Z<1) = P(Z=z AND Z < 1) / P(Z < 1).
I thought the top could be simplified to P(Z=z) for z < 1. Correct?
So,
f(z) = 0, for z > or = 1
f(z) = P(Z=z)/P(Z<1), for z < 1.
Correct?
What you have is essentially correct, although it seems bad form to use probabilities in the statement of a probability density function.
I think better is to write: Let g(z) be the PDF of Z = X + Y. If this is still the problem with Z = X + Y where X and Y are uniform on [0,1] that you've been working on in different ways, then you have this. But even if it's not you can just write it in terms of g(z).
So then:
[tex]f(z)=\left\{\begin{array}{cc}0,&\mbox{ if }<br /> z > 1\\ \frac{g(z)}{\int_{-\infty}^1 g(z) dz}, & \mbox{ if } z \leq 1\end{array}\right[/tex]
hgfalling, thank you so much for all the probability help!
