Probability function for the position of a static electron under no potential
  • Context: High School
  • Thread starter Thread starter Arend
The discussion centers around the possibility of defining a Gaussian probability distribution for the position of a static electron under no potential. Participants explore the implications of quantum mechanics on the uncertainty of an electron's position and the nature of wave functions associated with free electrons.
  • Some participants question whether it is possible to have a defined Gaussian for the electron's position, given that Gaussian parameters are often presented as undefined.
  • Others argue that the uncertainty in the Gaussian wavepacket arises from the accuracy of the measurement device rather than being a fundamental aspect of quantum mechanics.
  • A participant suggests that position uncertainty exists inherently for an electron, even in a static state, and that a wave function Ψ can yield a probability distribution |Ψ|^2 that might be represented by a Gaussian.
  • There is discussion about the challenges of preparing an electron in a "static" state and how the initial wave function depends on the preparation procedure.
  • Some participants express uncertainty about the extent to which an electron can be prepared in an exact Gaussian state, noting that wave-packets can theoretically take various shapes.
  • One participant highlights the distinction between mathematical models and experimental realities, suggesting that while a Gaussian wave-function can be assumed mathematically, it may not be physically realizable in experiments.
  • Concerns are raised regarding the variability of the electron's position uncertainty, with participants noting that it cannot be fixed or universally defined for all electrons.
  • Another point made is that the Gaussian wavefunction spreads indefinitely over time, leading to the conclusion that it is not a valid eigenfunction for a free electron.
  • Participants discuss the implications of the electron's initial position being influenced by its preparation context, emphasizing that the uncertainty in position is contingent on the experimental setup.
Participants express multiple competing views regarding the nature of the electron's position uncertainty and the feasibility of defining a Gaussian wave function. The discussion remains unresolved, with no consensus on the possibility of a defined Gaussian for a static electron.
Limitations include the dependence on definitions of "static" and "free" electrons, the role of measurement in determining wave functions, and the implications of state preparation on the uncertainty of position.
Arend
TL;DR
Is it possible to define an approximated Gaussian probability distribution for a free static electron position under null potential?
Found plenty of math expressions pointing to the equivalence of the wave function as a Gaussian wave packet, but always presenting the Gaussian parameters (~width, peak) as undefined. Is it possible to have a defined Gaussian for the electron position in this case? Thank you
Arend said:
TL;DR Summary: Is it possible to define an approximated Gaussian probability distribution for a free static electron position under null potential?
Find a random free electron and collapse its position. Let us assume, the device is somehow good at finding it within a certain uncertainty (so that the electron can be fairly described by a Gaussian wavepacket). The uncertainty in the Gaussian wavepacket comes from the accuracy of your detector, it is not a fundamental quantity that can be calculated or derived from postulates of quantum mechanics alone. Furthermore, the width of the Gaussian wavepacket increases with time.
pines-demon said:
"The uncertainty in the Gaussian wavepacket comes from the accuracy of your detector, it is not a fundamental quantity that can be calculated or derived from postulates of quantum mechanics alone. "
Does not position uncertainty exist inherently for an electron, even in a static state? So, there is a wave function Ψ associated, that results in a probability distribution |Ψ|^2, that can be represented by a Gaussian representation, no? Thanks
How do you know an electron is in a "static" state? You'd have to trap an electron and prepare it in some way. The initial wave function depends on that preparation procedure. The Gaussian is a nice mathematical function (with a variance parameter) that represents a particle with a spread of position that can be highly localised or spread out - and likewise with a spread of momentum.
I'm not sure to what extent you could prepare an electron in an exact Gaussian state. You could only estimate the wave-function from measurements on a large number of identically prepared systems. In general, a wave-packet can theoretically come in any shape. The Gaussian makes physical sense, as it's a probability distribution found extensively in nature.
Assuming the "static" state is pure theoretical, no trap procedure. The wave function can be only estimated by measurements? (can not be defined theoretically)
There is a key difference here between the mathematical model and experiment.
Mathematically, we can say: assume a free electron has an initial Gaussian wave-function with these parameters ... Then, we make predictions on the basis of that - perhaps to do with reflection and transmission probabilities at a potential barrier.
In terms of an experiment, we cannot put the electron physically into a Gaussian wave-packet. It's not like we can pour plastic into a Gaussian mould! Instead, we produce a free electron by some preparation procedure. You could search, for example, for "how does an electron gun work".
https://en.wikipedia.org/wiki/Electron_gun
We can do experiments with these electrons and if they are close enough to the theoretical/mathematical predictions, then we are getting somewhere. But, actually proving that our gun produces a Gaussian wave-packet may not be part of the experiment at all. The best you could do, perhaps, is to say that a Gaussian wave-packet provides a working model for the free electrons produced in our experiment.
So, the electron particle position uncertainty math model is not something that is fixed. I can not say, just as an example, that every electron, with low velocity, potentially free, has a standard deviation position of 5nm (or so) ?
Nope. Even the Gaussian wavefunction spreads indefinitely with time. This is called dispersion, the Gaussian wavepacket is not a valid eigenfunction of a free electron so it will spread. A valid stationary solution is a plane wave, where the electron has a definite momentum that you can verify but its position is completely delocalized in space.
Note that you can prepare the particle in many other ways to get different wavefunction (measure angular momentum for example, or some complicated quantity). There is no unique fundamental wavefunction to a free electron.
Would not be even possible to say that the electron (initial) position is inside of the plane wave wavelength? I guess that the Gaussian time dependency result is like a "random walk" for the electron.
No, unless we’ve done something to make it that way. Where did we find this electron? Bound in an atom? Product of beta decay? Boiled off a hot filament in an electron gun? Released by a chemical reaction in a battery? Is it in vacuum or surrounded by matter?
The uncertainty in the “initial position” of an electron depends on how we’ve set things up (“state preparation” in the lingo), just as the “initial length” of a piece of string depends on how we cut it from the roll.
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 21 ·
