Probability of Sum of Dice Rolls 10-15 Inclusive
  • Thread starter Thread starter theloathedone
    Dice Sum
The problem involves a 5-sided fair die being rolled four times, with the objective of finding the probability of obtaining a total score between 10 and 15, inclusive. The context is rooted in probability theory and discrete uniform distributions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the possibility of calculating probabilities by listing all potential sums, with some expressing concern about the tediousness of this method. Others suggest exploring simpler or more systematic approaches, including the use of generating functions and recursive relationships.
The discussion is ongoing, with participants sharing various methods and insights. Some have attempted to create tables to visualize outcomes, while others are questioning the assumptions and definitions related to the problem. There is a willingness to explore alternative methods, but no consensus has been reached yet.
Participants note the importance of correctly identifying singular and plural forms of "die" and "dice." Additionally, there is a recognition that the problem may involve tedious calculations, and some participants express a desire for visual aids or examples to clarify the concepts being discussed.
theloathedone
There is a 5-sided fair dice with faces showing 1, 2, 3, 4, 5 dots. The dice is rolled four times. Find the probability of getting a total score between 10 and 15 (inclusive).
If X is the score from one roll, then it follows a discrete uniform distribution with parameter 5.
I'm really clueless as to how to start. I can only think of writing out all the possible sums and finding the probability. But that seems rather tedious, is there a better way?
"dice" = plural
"die" = singular
So, you have one die.
Can you at least show your calculations in the easiest cases, with total = 4 and total = 5? (What I mean is: when you say you can write it out---well do just that: write it out.) That would prove that you at least know what to do using a brute-force method. After that, I would be willing to show you some tricks (actually, standard methods) that make the computations for total = 10, 11, 12, ... much, much easier.
R.G. Vickson
Ok, what I did was to draw out two tables. The first one is here:
1st Dice 1 2 3 4 5
2nd
1 2 3 4 5 6
2 3 4 5 6 7
3 4 5 6 7 8
4 5 6 7 8 9
5 6 7 8 9 10
If Y = X1 + X2
So P(Y = 2) = 1/25 = P(Y=10), P(Y=3) = 2/25 = P(Y = 9), P(Y=4) = 3/25 = P(Y=8), P(Y=5) = 4/25 = P(Y=7), P(Y=6) = 5/25.
Then I drew out another table, since the total T = Y1 + Y2, where the row and column headers are from 2 to 10, and I wrote the probability next to each of them. Then I found all the possible sums and added it all up one by one. The answer I got was 433/625 = 0.6928
But that's really tedious and I hope to learn a better way :)
1st Dice 1 2 3 4 5
2nd
1 2 3 4 5 6
2 3 4 5 6 7
3 4 5 6 7 8
4 5 6 7 8 9
5 6 7 8 9 10
"Die", not "dice"!
If Y = X1 + X2
OK, but *all* methods are a bit tedious in this type of problem. One more-or-less standard method for getting the sum of k independent, identically discrete random variables, each with distribution P{X=0} = p0, P{X=1} = p1, ..., P{X=r} = pr, with p0, p1, ..., pr >= 0 and sum{p_j, j=0..r} = 1, is to use the so-called *moment-generating function*, q(z) = p0 + p1*z + p2*z^2 + ... + pr*z^r. This is a polynomial in z of degree r. Now, it is fairly easy to show that the generating function of a sum of independent random variables is the product of their generating functions, so the generating function for S = X1 + X2 + X3 + X4 is Q(z) = q(z)^4. In your case, q(z) = (1/5)f(z), where f(z) = z + z^2 + z^3 + z^4 + z^5, so Q(z) = (1/5^4)(z + z^2 + z^3 + z^4 + z^5)^4. If we expand this out, the coefficient of z^i is the probability that S=i.
This is still tedious, but we can approach it recursively: we have a product f(z)*[f(z)*f(z)*f(z)]. Each factor contributes to z^i. In fact, if we have z^j1 from factor 1, z^j2 from factor 2, etc., the total is z^(j1+j2+j3+j4), so we need j1+j2+j3+j4=i. The coefficient of z^i is the total number of combinations {j1,j2,j3,j4} that sum to i; call it N4. How can we get N4? Well, if the first factor contributes z^j the remaining three must contribute i-j, and the number of these is N3[i-j]. Each j makes such a contribution, so the total is N4 = sum{N3[i-j], i=1..5} for i >= 8, while N4 = sum{N3[i-j], j=1..min(5,i-3)} for i = 4, 5,6,7. So, if we know N3[k] for k=3,...,15 we can get all the N4.
Similarly, N3 = sum{N2[i-j],j=1..min(5,i-2)} for i = 3, ..., 15, etc. These are most straightforward if we just let N1 = 0 for i <= 0 and for i >= 6. Then N2 = sum{N1[i-j] ,=1..5} holds for all i. Then we let N2=0 for i <= 1 and for i >= 11. This let's us write N3 = sum{N2[i-j]. j=1..5} for all i, etc.
To do this by hand is reasonably straightforward but somewhat tedious, although less tedious than other methods. It can all be done effortlessly in a spreadsheet, for example.
RGV
I would sure like to see a picture of this "5-sided fair die".:wink:
Haha me too.
Thanks Ray for the help, I'll try to understand it :)
Ray, please be advised: we do not do homework for people here. We guide them the answer.
I was thinking the same thing but it's not hard to do. A fair die does not have to be a regular polyhedron.
You can make a fair die of any number from 2 to theoretically infinite.
Start with a prism with the requisite number of sides and just round off the ends. The die can only come to rest in one of five equally likely configurations.
  • · Replies 53 ·
11K
