Probability problem - from another forum
  • Context: Graduate
  • Thread starter Thread starter Stephen Tashi
    Forum Probability
The discussion revolves around a probability problem involving a six-sided die with unknown probabilities for each face. Participants explore how to express the probabilities of each face landing first in a sequence of independent tosses based on given probabilities for each face being the first to land 100 times.
  • Some participants propose calculating the probabilities of getting 100 heads or tails in a series of tosses, suggesting that this can be extended to include a third outcome.
  • Others argue that the problem can be reduced to simpler cases, although they acknowledge the complexity of the resulting expressions.
  • A participant presents a formula for the probability of getting 100 heads first, involving a summation that incorporates the probabilities of heads and tails.
  • Some participants discuss the implications of different game structures on winning probabilities, suggesting that longer games may amplify advantages held in simpler games.
  • One participant notes the potential for "perverse" games where advantages in short games could translate to disadvantages in longer formats.
  • Another participant expresses concern about the computational challenges posed by large numbers in their calculations, suggesting the use of logarithmic storage to manage precision issues.
Participants express a range of views on the methods for calculating probabilities, with no consensus on the best approach or the implications of different game structures. The discussion remains unresolved with multiple competing ideas and methods presented.
Participants mention limitations related to the complexity of the mathematical expressions and the potential for large numbers in calculations, which may affect the feasibility of certain approaches.
Stephen Tashi
Homework Helper
Education Advisor
This interesting problem was posted on another math forum (http://www.sosmath.com/CBB/viewtopic.php?f=6&t=62620):
The probability that a six sided (possibly loaded) die lands on the ith face is P_i. The P_i are unknown. We are given the values of S_i = the probability that the i_th face is first to land 100 times in a sequence of independent tosses of the die. Find the P_i as functions of the S_i.
Although you cannot bias a coin, let's start with just heads and tails:
For each k from 100 to 199, we can calculate the probability to get 100 times heads and the probability to get 100 times tails. The resulting expression might look ugly, but not hard to set up.
Now we can add a third side to the coin ("corner"). For each k from 100 to 198, we can calculate the probability to get 100 corners - and for k where (heads+tails) exceeds 100, we know the probability that we stop from the previous step.
I think in this way it is possible to reduce the original 100^6 problem to five problems with ~100-500 cases with explicit formulas for each case.
I get this for the probability that you get 100 heads first.
\sum_{k=0}^{99} \frac {(99+k)!} {99! k!} {P_h}^{100}{P_t}^k the k'th term is the probability of first getting 99 heads and k tails in any order, and then a single head.
I think you meant for k from 100 to 298?
I don't think it's that easy. I think you get a double summation, where you have to sum over the total number of throws as well as over the number of heads or tails.
Oh typo, should be 298, yes.
Yeah, you get a sum with the previous sums as summands. So what? Still something you can write down, or calculate.
Using the Negative Binomial CDF this can be expressed in terms of the regularised incomplete Beta function
1-I_{P_t}(100,100)=I_{P_h}(100,100)
Some intuitive musings:
Suppose I'm required to bet on face 1 "winning" in game of independent random tosses, but I have a choice about what what game is played. I can pick from games like "best 1 out of 1", "best out of 7", "first to occur 5 times in a row", "first to happen 100 times", etc.
My intuition is that if I have the advantage that the probability p[1] of face 1 coming up is greater than the other p then I have a better chance of winning in the games that can involve more throws than the "1 out of 1" toss game.
My intuition says that my chances of winning any of those games are greater if the probability of the other faces 1 - p[1] is divided equally among the the other faces (maximizing their competition with each other, so to speak).
One could define "perverse" games where the player with advantage in "1 out of 1" game has a disadvantage in games of longer length. However, in natural examples ( best n out of m, first n in a row, first to occur n) I think the longer length of the game amplifies the advantage a player holds in a "1 out of 1' game. I wonder if there is general mathematical argument that this is true.
Stephen Tashi: Sure, that should be clear as for longer games the relative standard deviation goes down.
I don't think you can go above 50%, but certainly above 1/6:
Let p1=0.4, p2=0.6, pi=0 otherwise, you need 1s to win.
"1 out of 1" has a winning probability of 0.4, "first to get 100" (="best of 199") has a winning probability of just 0.23%.
OK, this illustrates my inutuition that if you have an advantage in the "1 out of 1" game then the longer games favor you even more. If you are at a disadvantage, you have a greater disadvantage in the longer games.
The probability with 6 faces on the die with probabilities P1...P6 and the probabiltiy to get the 1 face to 100 first is:
\frac {{P_1}^{100}}{99!} <br /> <br /> \sum_{k_2 =0}^{99} \frac {{P_2}^{k_2}} {{k_2}!} <br /> \sum_{k_3 =0}^{99} \frac {{P_3}^{k_3}} {{k_3}!} <br /> \sum_{k_4 =0}^{99} \frac {{P_4}^{k_4}} {{k_4}!} <br /> \sum_{k_5 =0}^{99} \frac {{P_5}^{k_5}} {{k_5}!} <br /> \sum_{k_6 =0}^{99} \frac {{P_6}^{k_6} (99 + k_2+k_3+k_4+k_5+k_6)!} {{k_6}!} <br /> <br />
I think I see how to compute this.
I think I can put the result of the innermost summation in a table with 400 elements, since it only depends on k2+k3+k4+k5.
The result of the 2 innermost summations only depends on k_2+k_3+k_4, so it can fit in a 300 element table. The 3 innermost summations fit in a 200 element table and the 4 innermost in a 100 element table.
All the tables will have to be recomputed when any of the Probabilities change.
This would make it fast enough to use some root finding algorithm to get P1...P6 from S1...S6. 6 variable root finding will be tricky tough.
That looks similar to the approach I suggested in post 2, thanks for the formula.
Inverting that looks way too messy, but numeric approaches should work as increasing/decreasing Pi will always increase/decrease Si.
The first problem that pops up when implementing it, is that the numbers involved can get larger than the maximum of double precision floating point numbers. I could use a multipecision library, but I don't need the extra precision, just a larger exponent.
I need to compute 1000 table values, and sum 100 numbers for each table value, and then repeat 6 times for each Si to compute, and then repeat the computation many times to find the rootm so I'd rather not use a multiprecision library. Maybe I can store the numbers as logarithms?
9K
