Probability puzzle
  • Context: Graduate
  • Thread starter Thread starter WMDhamnekar
    Probability theory
22 replies · 4K views
WMDhamnekar
MHB
TL;DR
Two players start 1 meter away from a target. They simultaneously begin moving towards the target at a same constant speed. Target hitting probability of both the players when they are X meters from the target are given. If both players misses or hits the target simultaneously, neither wins and game will be started over. The player whoever hit the target first will win.What is the probability that left player wins, if both player uses optimal strategies?
Two players start 1 meter away from a target. They simultaneously begin moving towards the target at a same constant speed. If the left player shoots when he is X meters from the target, his shot hit with a probability 1-X. If the right player shoots when he is X meters from the target, his shot hits with a probability [##1- X^2 ##]. Each player has exactly one bullet and may choose to shoot at any time during the walk. If exactly one player hit the target, that player wins. If both players shoot simultaneously and both hits , then neither player wins. Both are sent back to the starting positions and game starts over. Similarly, if both the players miss the shots, the game starts over from the beginning. The players don't have to shoot at the same time and they can see each other at all times. If they both hit the target, but at different times, whoever hits the target first will win. Assuming both players use optimal strategies, what is the probability that the left player wins? Note: Though, both players uses pistol, they are not criminals,violence supporter.
My answer: I don't under stand how to answer this question. I am still working on this question. If any physics forum's members knows the answer to this question may reply with correct answer.
Reply
$$1-x^2=(1-x)(1+x)>1-x$$
I know that the right player has advantage. I do not think the left has a strategy to win with more than 50% probability.
At first both players are better off hoping for the other guy to fire first and miss. There comes a point where firing and waiting are of equal value. That's when x is about 0.618 m. After that both players are better off firing. Each is more likely to hit than the other guy is to miss so you'd better go for it even if the odds are against you. Unless you think the other guy won't figure it out and you can wait some more then fire first.
Lefty might hope that firing for a tie at 0.618 will help but it makes things worse. If righty can (unrealistically) fire at the same moment as lefty then that's a good plan until I'm not sure when.
Reply
I see the same. At any distance greater than D = 0.618 m each player's best strategy is to wait, regardless of the other player's strategy. At any distance less than D each player's best strategy is to fire just before the other player fires. Since each player knows that the other player is also playing optimally, they will both fire at D.
$$p_1(r)+p_2(r)=1$$
gives optimal firing position r for both the players where ##p_i(r)## is the probability of success of i-th player at position r.
In this particular case
$$1-r+1-r^2=1$$
$$r=\frac{\sqrt{5}-1}{2}$$
$$p_1=\frac{3-\sqrt{5}}{2}$$
$$p_2=\frac{\sqrt{5}-1}{2}$$
Success probalities of fire (red ) and wait (blue ) for player 1
Success probalities of fire (red ) and wait (blue ) for player 2
PS
Three players case,e.g.,
$$p_1(r)=1-r$$
$$p_2(r)=1-r^2$$
$$p_3(r)=1-r^3$$
seems interesting though I have not solved it yet. My easy conjecture is that r which satisfies
$$p_1(r)+p_2(r)+p_3(r)=1$$
is the common optimal distance to shoot.
Say you are at D. If the other guy fires first then your best move is to not fire until at point blank. Firing first gives no advantage but firing second is always bad. It is not clear what the best plan is. Maybe to fake the other guy into firing first then hold your fire so you will never be second. Or fire slightly before D to reduce the chance of the other guy firing first. But then the other guy might do the same. So you try to anticipate what your opponent will do but this seems beyond mathematics.
This sort of thing is prevalent in expert-level real world games and sports.
We are given that both players play optimally. We were not given it, but I also assumed that both players know the other player is also optimal. That knowledge is essential for knowing that the optimal strategy is D.
If the opponent were random or had some other strategy then that would change the optimal strategy.
But both firing at the same instant is not optimal for Lefty. It favors Righty. This is included as a possibility in the problem statement.
It does favor the right player, but it is still optimal for the left player also. In other words, the game is rigged. The optimal outcome for the left player still favors the right player.
The difference comes when Righty can fire at the same time as Lefty. If if they both fire at exactly .618 it boosts Righty's chance of victory from 62% to about 71%. Lefty wants to avoid ties in firing time, which are allowed. If both fire at the same time and have the same result then there is a rematch. Righty wants to cause such situations.
Reply
I would estimate it using post #5
$$p_1=0.381966... , p_2= 0.618033...$$
where 1 is left and 2 is right.
Firing at the same time in that optimal case
Probabilities of
Player 1 wins : ##p_1(1-p_2)=p_1^2##
Player 2 wins : ##p_2(1-p_1)=p_2^2##
No contest : ##1-p_1^2-p_2^2##
Relative probability of Player 1 wins : $$\frac{p_1^2}{p_1^2+p_2^2}=\frac{5-\sqrt{5}}{10}= 0.276393...$$
Relative probability of Player 2 wins : $$\frac{p_2^2}{p_1^2+p_2^2}=\frac{5+\sqrt{5}}{10}= 0.723606...$$
So co-firing at the optimal distance is advantageous for Player 2, right player. The rich becomes richer and the poor becomes poorer.
Player 2 does not hesitate to fire at the optimal distance. Understanding it Player 1 fires at distance 0 in case Player 2 fails. The optimal probability ##p_1,p_2## take place.
The basic strategy behind : when you observe his firing (on purpose, in accident or in any manner) wait firing until you reach distance 0 if you have not fired yet. With this starategy one's failure probability equals the other's success probaility.
Player 2 thinks "He does not fire until distance 0. I will fire in closer distance for higher probability"
Player 1 thinks "He thinks so. So I should be a first shooter sometimes to break it"
and so on. Such a strategy struggle is a tough thing for mathematics and physics.
I think ##p_1,p_2## has meaning even in these tactics struggle. We may be able to disregard simultaneous shooting in chance because of its infinitesimal probability. I conjecture that such a chickin race would take players away from the optimal distance firing but not so much and as a kind of fluctuation. .
Ah, I missed the tie -> rematch condition.
That makes the optimum a little difficult. I would guess that the left player would want to fire infinitesimally after D then. But I have not worked it out to confirm.
Ok, so the issue isn’t that a tie favors the right player (the whole game does), but that for the left player a tie at D represents a finite “marginal” loss from the optimal D without a tie. Let's call that marginal loss L.
If the left player employs a strategy of firing at a non-D distance, then that strategy incurs a marginal loss, and there is some finite region around D where that marginal loss is less than L. If the left player chooses to fire at any distance in that region, then they are worse off than they would be at D without a tie, but better off than they would be at D with a tie. So they want to randomly choose a distance within that interval. The statistical distribution should have an expectation of D, be zero outside of the finite region (and maybe also at D), a minimal variance, and minimize the probability of a tie.
Any finite continuous distribution will have 0 probability of an exact tie. That doesn't mean that a tie is impossible, but its probability is so small that it won't affect the expectation. And there are plenty of distributions that are only non-zero in the region and with an expectation of D. So, the only problem is the minimal variance. There simply is no such thing. For any qualifying distribution with any finite variance there is another one with less variance.
So, I don't think that the left player has an optimal strategy, but there are strategies that are arbitrarily close to optimal. The right player would still stick with D since the expected value of trying to get the tie is 0.
I have to admit that I cannot prove any of this. I could be wrong. Also, it would be more interesting if the distances were discrete, then the probability of a tie could not be made 0, and there might be an actual optimal strategy for the left player.
Since this is supposedly a real situation a tie occurs when the measurement system can't distinguish the two shots. The measurement system has finite resolution so the probability is above zero. Said system might be a tipsy mustachioed second in tails and a waistcoat so it could be significant. Will assume that Righty does not have the skill to generate ties at will, which would be an advantage to him/her.
At D Lefty's accuracy is increasing more rapidly than Righty's so Righty will never wait and fire after that. Righty's best shot is to fire at D. Then Lefty's best chance is to fire slightly before D, sacrificing a minor percentage in order to avoid a tie. If Lefty misses the target then Righty's best strategy is to not fire at all until at point blank range where he/she will certainly win. So Lefty wants to wait until it is too late for Righty to stop himself from firing at D, but also fire before there is a significant chance of a tie.
In Tokyo the Seiko watch museum has the measurement system they made for the 1960 Olympics. The visitor is given a clicker and the game is to click at the exact moment a counter has counted down to zero. I got within .007 seconds, which is very good. It comes from many years of playing the bass guitar. Bass guitars usually have very simple parts to play, the skill comes in starting and stopping the notes at exactly the right time. This sort of skill is also important in drag racing, where at the start the drivers are given a countdown. One must take one's own action time into account. Waiting until you see the start signal is a disadvantage. But start too early and you are disqualified.
We have to make an assumption about realism.
Can each duellist observe the other pulling the trigger and respond rapidly enough to achieve a dead heat (in terms of moment of firing) deliberately? If not, we can consider a dead heat effectively impossible.
Either way, in general, we may need to look for a solution in mixed strategies (Nash equilibrium). That is, each has an optimal probability distribution of when they will fire, and each can be assumed to know what the other's distribution is.
In the no dead heat model, these distributions have a continuous density function. In the other, it is complicated by a discrete element, a nonzero probability of choosing to fire exactly when the opponent does (by reacting, not by knowing in advance when that will be). Note that it cannot be by advance knowledge since, as noted in earlier posts, such a solution is unstable; the other duellist would simply fire slightly sooner than initially calculated.
I calculate that choosing to dead heat at distance x (repeatedly) gives the better shot the eventual success probability ##\frac{1-x^2}{1+x-2x^2}##. If that is right, the only solution will be as mixed strategies. If each fixes on a deterministic strategy they get stuck in a loop anywhere between x=.5 and x=.618… That is the range of distances for which the better shot gets
  • her best outcome if both choose x
  • the middling outcome if she chooses x and the other waits
  • the worst outcome if the other chooses x and she waits
In that range:
  • if both choose x, worse shot can do better by delaying
  • better shot can then improve by delaying also, but by a little less
  • worse shot then improves by returning to x
etc.
Righty fires at 0.618. Lefty then holds fire until point blank range, or fires if Righty fails to fire at 0.618.
That does not define a stable solution. Exactly how long does L wait to decide R has failed to fire? If L waits for ##\Delta t## then R will delay ##\Delta t##, so L waits ##2\Delta t##…
The problem is to find a pair of strategies, each a fixed probability distribution known to the other, such that neither can improve by changing theirs. That such a pair exists follows from Nash's theorem.
Figure it out and show us the solution.
Working on it, but I don’t see an analytic way and I can’t get an accurate numerical result before the program exceeds its execution time.
Reply
Well, I have a result, but hard to be sure how accurate it is.
R has probability of about 0.625 of winning. The strategy distributions are both, graphically, and with some smoothing
The peak is at distance 0.56. Note the slight asymmetry.
Some notes on my method:
I divided the 1m distance into cm. Both firing in the same cm is a dead heat.
I did not allow a deliberate choice of dead heating.
I started with flat distributions for both. An iterative process tried adjusting the strategy of each in turn, accepting the adjustment if it was an improvement for that person, reverting to previous strategy otherwise.
Each adjustment consisted of picking two distances at random, the first currently having a nonzero chance of that person firing and the second a less than 100% chance. Each random selection was repeated until a suitable distance was found.
Having chosen the two distances, the maximum transferable was calculated (min(p1, 1-p2)) and a fraction of that was transferred.
The transferable fraction started at 0.1 and gradually reduced over iterations.
In the dead heat case, if both miss or both hit then the outcome was taken to be that calculated in the preceding iteration.
p1=0.381966...,p2=0.618033...
Using this optimal case, Plyaer 1 Left would find a strategy which he ties with Player 2 Right.
Say Player 2 shoots at this optimal distance in case he has found no shooting of Player 1.
Player 1 shoots a tiny bit before the optimal distance so that Player 2 does not recognaize it due to finite light speed. Player 2 cannot stop shooting.
Player 1 wins with probability of about
$$p_1 \approx 0.38 $$
Player 2 wins with probability of about
$$p_2(1-p_1)=p_2^2 \approx 0.38 $$
No contest with probability of about
$$1-0.38-0.38 \approx 0.24 $$
It is almost tie. Very high simultaneous resolution is assumed for example with light lay guns and high time resolution detectors. This starategy may be valid only once. Player 2 would change his strategy to make this strategy fail.
Which means it is not a solution to the problem. Each player can anticipate the other’s strategy. If player 2 calculates player 1's best strategy then player 2 can reconsider her own strategy. But player 1 can anticipate that, and so on.
Please read posts #17 and #20, and see https://en.wikipedia.org/wiki/Nash_equilibrium
Reply
In case :
##\frac{1m}{v} >>## time resolution width of simultaneity ##>>\frac{1m}{V_{bullet}},##time for information processing and shooting action
The players can make use of simultaneity shooting rule : In case the first succeeds, the second shoot within the time resolution to disuturb the success of the first. Otherwise the second shoots at the goal.
The probabilities of:
The first shooter wins
$$p_{1st}(1-p_{2nd})$$
The second shooter wins
$$1-p_{1st}$$
Draw
$$p_{1st}p_{2nd}$$
Graphs of probability - distance
Red ; 1st shooter wins
Blue : 2nd shooter wins
Green; Draw
Purple: ratio Red/Blue
1st shooter has success probability 1-x 2nd shooter : 1-x^2
1st shooter find maximum benefit at x=0.5 with the ratio 0.25.
1st shooter : 1-x^2 2nd shooter : 1-x
1st shooter finds maximum benefit at x ##\rightarrow ## +0 with the ratio infinity. The ratio at x=0.5 is 1.5 < 1/0.25 = 4 which mean no benefit to be the first shooter.
Sharing all these information 1-x probability player would be the first shooter at x=0.5, which seems a good candidate of optimal case.
