Probability that the driver is from G3
  • Thread starter Thread starter 2RIP
    Probability
The discussion focuses on calculating the probability that a randomly selected driver with no accidents is from group G3, given the proportions of drivers and their accident rates. The initial approach using conditional probability was questioned, as it resulted in a zero probability. A brute force method was suggested, where the number of no-accident drivers from each group is calculated, leading to a proportion of G3 drivers among them. The final calculation using conditional probability yielded a result of 10/72, simplifying to approximately 0.139, indicating that about 13.9% of no-accident drivers are from G3. The conversation emphasizes the importance of correctly applying probability formulas to arrive at accurate conclusions.
2RIP
There are three groups of drivers in a city: G1, G2, and G3.
G1 make up 30% of drivers, G2 make up 50% of drivers, and G3 make up the remaining 20% of drivers.
P(at least one accident for G1)=0.1 = P(A1)
P(at least one accident for G2)=0.3 = P(A2)
P(at least one accident for G3)=0.5 = P(A3)
If we randomly select a driver out of the groups and the driver has no accident, what is probability that the driver is from G3?
I tried P(G3 | (A1^{c} \cap A2^{c} \cap A3^{c})). Is this is the right method of solving such a question? The probability I got from this happened to be zero which sort of confirms that it's incorrect. Any advice will be great.
Thanks a lot.
Thanks a lot.
I like the brute force way since I don't know the notation. Assuming one hundred drivers in proportions given, 30 G1 drivers, etc. 1- prob of one accident is prob of no accidents, right ? So there are 27 no accident G1 drivers. Add up all the no accident drivers for G2 and G3, should be 72. What proportion of these 72 are G3 ? Well, there are 10 no accident G3 drivers, so 10/72 is probability.
It would be nice if the answer could be put in a form more in line with advanced probability thinking. So...?
For conditional probability: P(A\mid B)=\frac{P(A and B)}{P(B)}
So in this case A represents G3 and B represents no accident.
\frac{20*.5}{30*.9+50*.7+20*.5} = 10/27
I would not say that this "improves" the answer whatsoever, or even whether it applies.
First trick I learned this one a long time ago and have used it to entertain and amuse young kids. Ask your friend to write down a three-digit number without showing it to you. Then ask him or her to rearrange the digits to form a new three-digit number. After that, write whichever is the larger number above the other number, and then subtract the smaller from the larger, making sure that you don't see any of the numbers. Then ask the young "victim" to tell you any two of the digits of the...
  • · Replies 29 ·
  • · Replies 18 ·
