Can Gravitational Force Depend on Medium Like Electric Force Does?
  • Thread starter Thread starter waqarrashid33
The discussion centers on the principle of equivalence and its implications for gravitational force in different mediums. It highlights that while gravitational effects are primarily determined by the curvature of spacetime, the medium can influence gravitational effects through its mass and energy, leading to minor adjustments rather than significant changes. Tidal effects in non-uniform gravitational fields are acknowledged as a key distinction from simple acceleration. The concept of gravitational lensing is mentioned as an example of how a large medium can affect gravitational fields. Overall, the gravitational force does not depend on the medium in the same way electric force does with dielectric materials.
waqarrashid33
I had a problem that the principle of equilance is saying that one can't say either he is acclerating upward or standing in garvity.
but i am saying that it is possible b/c in gravity when two bodies are falling under the action of gravity then as time passes they become closer to each other while in simple accleration this does,t happens,
why?
hi waqarrashid33! :wink:
yes, you're correct :smile:
the difference would only be undetectable in a uniform gravitational field …
in any other field, there will always be a slight difference (known as "tidal effects")
for details, see http://en.wikipedia.org/wiki/Principle_of_equivalence#The_Einstein_equivalence_principle", including …
The Einstein equivalence principle states that the weak equivalence principle holds, and that:
The outcome of any local non-gravitational experiment in a freely falling laboratory is independent of the velocity of the laboratory and its location in spacetime.
Here "local" has a very special meaning: not only must the experiment not look outside the laboratory, but it must also be small compared to variations in the gravitational field, tidal forces, so that the entire laboratory is freely falling. It also implies the absence of interactions with "external" fields other than the gravitational field.​
Is garvitational force depend upon meium?
What "medium" are you talking about?
similar to the multiplicative difference to electric force caused by the dielectric?
my immediate reaction is to say "no" …
gravitational effect depends only on the metric of space-time (the curvature coefficients), and will be the same whatever the medium …
however the medium itself has a gravitational effect, from its mass, from its pressure, and from any other form of energy in it, so in that sense it makes an additive difference …
ie a tiny adjustment, but not a multiplicative difference that scales-down any "outside" gravitational effect
on the other hand, there is such a thing as gravitational lensing, which i suppose is in a sense a way in which a truly enormous amount of medium can influence the gravitational field
(and if anyone ever manages to develop a workable theory of quantum gravity, i suppose that may show some "dielectric" effects)
perhaps you should have raised this in a separate thread?​
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 27 ·
  • · Replies 84 ·
