Problem in Perfectly Elastic Collision w/o given mass
In a perfectly elastic collision involving two identical bodies with initial velocities of 4 m/s and 6 m/s, the conservation of momentum and kinetic energy principles apply. Since the bodies have the same mass, they effectively exchange their velocities upon collision. The body initially moving at 4 m/s will move at -6 m/s after the collision, while the one at 6 m/s will take on the velocity of 4 m/s. This outcome can be validated by considering the conservation of energy, which is fundamental in elastic collisions. Understanding these principles is crucial for solving problems related to elastic collisions.
naiian02
what formula/s should i use in this problem:
2 identical bodies move forward each other. One has a velocity of 4 m/s and the other has a velocity of 6 m/s assuming a perfeclty elastic collision. Find their velocities after collision
pls help me p. elastic col is not included in my book XD
What's conserved?
Kind of hard to believe that a book that doesn't cover elastic collisions would have a problem involving elastic collisions. What book are you using?
Ooh, these questions are really beautiful.
To make the math MUCH MUCH more simple, move your observer to the center of mass frame.
Try and come up with a SIMPLE expression dealing with the relative velocities of the two objects before and after colliding. You'll be surprised.
naaiin: Look in your text for the definition of an eleastic collision. Check the chapter with this problem, and look in the book's index.
Saying a collision is 'elastic' actually gives you a lot of information about it.
m1u1 + m2u2 = m1v1 + m2v2
its wad I've been taught in my school...
2 identical bodies means both object is the same...
assuming both objects have the same mass...
in a perfect elastic collision, both objects exchange velocity...
so the 1 that has 4ms-1 now has -6ms-1 while the 2nd 1 will be having 4ms-1
i'm not 100% sure of this though...do correct mii if any1 sees flaw in my statement...
It's true. Ignoring the time of the collision, it is as if they went "through" each-other. Unless you distinguished the two by coloring them, or some other method, you wouldn't know if there was a collision or if each just retained its velocity. :)
Try and prove this with considerations of energy, though. That's the key point of the exercise.
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 16 ·
