Problem of the Week #132 - October 6th, 2014
  • Thread starter Thread starter Chris L T521
The problem presented involves calculating the center of gravity of a square lamina defined by the vertices (0,0), (1,0), (0,1), and (1,1), with density proportional to the square of the distance from the origin. The mass of the lamina is determined using the double integral of the density function, resulting in a mass of m = (2k/3). The moments about the axes are calculated to be M_y = (5k/12) and M_x = (5k/12), confirming the symmetry of the lamina. Consequently, the center of gravity is found to be at the coordinates (5/8, 5/8).
  • Understanding of double integrals in calculus
  • Familiarity with the concept of center of mass
  • Knowledge of density functions and their applications
  • Experience with mathematical notation and integration techniques
  • Study the application of double integrals in physics and engineering contexts
  • Learn about different density functions and their implications on mass distribution
  • Explore the concept of symmetry in geometric shapes and its effect on center of mass calculations
  • Investigate advanced integration techniques for solving complex problems in calculus
Students and professionals in mathematics, physics, and engineering fields who are interested in understanding the principles of mass distribution and center of gravity calculations.
Chris L T521
MHB
Here's this week's problem!
Problem: Find the center of gravity of the square lamina with vertices $(0,0)$, $(1,0)$, $(0,1)$ and $(1,1)$ if the density is proportional to the square of the distance from the origin.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
This week's problem was correctly answered by MarkFL. You can find his solution below.
[sp][box=blue]We define the mass of the lamina by the double integral:
$$m=\iint\limits_{R}\rho(x,y)\,dA\tag 1$$​
We define the coordinates of the center of mass (or gravity) of the lamina by:
$$\overline{x}=\frac{M_y}{m}\quad\overline{y}=\frac{M_x}{m}\tag 2$$​
where:
$$M_y=\iint\limits_{R}x\rho(x,y)\,dA\quad\text{ and }\quad M_x=\iint\limits_{R}y\rho(x,y)\,dA\tag 3$$​
are the moments of the lamina about the $y$- and $x$-axes respectively.[/box]
For this problem, we are told:
$$\rho(x,y)=k\left(x^2+y^2\right)$$
And so, using (1) we find that the mass $m$ of the given lamina is:
$$m=k\iint\limits_{R} x^2+y^2\,dA=k\int_0^1\int_0^1 x^2+y^2\,dx\,dy=k\int_0^1\left[\frac{x^3}{3}+xy^2\right]_0^1\,dy=k\int_0^1\frac{1}{3}+y^2\,dy=k\left[\frac{1}{3}y+\frac{1}{3}y^3\right]_0^1=\frac{2k}{3}$$
Now, using (3), we find:
$$M_y=k\iint\limits_{R} x^3+xy^2\,dA=k\int_0^1\int_0^1 x^3+xy^2\,dx\,dy=k\int_0^1\left[\frac{x^4}{4}+\frac{x^2}{2}y^2\right]_0^1\,dy=\frac{k}{4}\int_0^1 2y^2+1\,dy=\frac{k}{4}\left[\frac{2}{3}y^2+y\right]_0^1=\frac{5k}{12}$$
$$M_x=k\iint\limits_{R} yx^2+y^3\,dA=k\int_0^1\int_0^1 yx^2+y^3\,dx\,dy=k\int_0^1\left[y\frac{x^3}{3}+xy^3\right]_0^1\,dy=\frac{k}{3}\int_0^1 3y^3+y\,dy=\frac{k}{3}\left[\frac{3}{4}y^4+\frac{y^2}{2}\right]_0^1=\frac{5k}{12}$$
As we would expect, the moments of the lamina are the same, given the symmetry of the lamina about the line $y=x$, and so we would expect that the center of gravity would lie on this line.
Hence, by (2), we find:
$$\overline{x}=\overline{y}=\frac{\dfrac{5k}{12}}{\dfrac{2k}{3}}=\frac{5}{8}$$
Thus, we find that the center of gravity of the given lamina is:
$$(\overline{x},\overline{y})=\left(\frac{5}{8},\frac{5}{8}\right)$$[/sp]
