Is $f$ Constant if Distance Between Points is Raised to a Power Greater than 1?
  • Context: Undergrad
  • Thread starter Thread starter Euge
If a function $f$ maps from $\Bbb R$ into a metric space $(X,d)$ and satisfies the condition $d(f(x),f(y)) \le |x - y|^{\gamma}$ for some $\gamma > 1$, then $f$ must be constant. This conclusion is derived from the properties of metric spaces and the implications of the distance condition raised to a power greater than one. The discussion highlights the significance of the metric properties in determining the constancy of the function.
  • Understanding of metric spaces and their properties
  • Familiarity with the concept of function continuity
  • Knowledge of real analysis, particularly limits and convergence
  • Basic understanding of mathematical proofs and inequalities
  • Study the properties of metric spaces in detail
  • Explore the implications of the Heine-Borel theorem
  • Learn about uniform continuity and its relationship to function behavior
  • Investigate other conditions that imply constancy in functions
Mathematicians, students of real analysis, and anyone interested in the properties of functions within metric spaces will benefit from this discussion.
Euge
MHB
POTW Director
Here is this week's POTW:
If $f$ is a function from $\Bbb R$ into a metric space $(X,d)$ such that for some $\gamma > 1$, $d(f(x),f(y)) \le |x - y|^{\gamma}$ for all $x,y\in \Bbb R$, show that $f$ must be constant.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to castor28 and Opalg for their correct solutions. You can read Opalg’s solution below.
Let $x\ne0$. By the triangle inequality $$\begin{aligned} d(f(x),f(0)) &\leqslant \sum_{k=0}^{n-1}d\bigl(f\bigl(\tfrac{kx}{n}\bigr), f\bigl(\tfrac{(k+1)x}{n}\bigr)\bigr) \\ &\leqslant \sum_{k=0}^{n-1}\Bigl|\frac xn\Bigr|^\gamma = \frac{n|x|^\gamma}{n^\gamma} \to0\ \text{as }n\to\infty \end{aligned}$$ (because $\gamma>1$). Therefore $d(f(x),f(0)) = 0$ and so $f(x) = f(0)$. Since that holds for all $x$, it follows that $f$ is constant.
