What is the proof that a commutative ring with prime proper ideals is a field?
  • Context: Undergrad
  • Thread starter Thread starter Euge
Every commutative ring \( A \) with unity, where every proper ideal is prime, is definitively a field. This conclusion is supported by the solutions provided by Olinguito, Ackbach, and castor28 in the forum discussion. The proof hinges on the properties of prime ideals and the definition of a field, establishing that the only ideals in such a ring are the trivial ideal and the ring itself.
  • Understanding of commutative rings and their properties
  • Knowledge of prime ideals in ring theory
  • Familiarity with the definition and properties of fields
  • Basic concepts of algebraic structures in abstract algebra
  • Study the properties of prime ideals in commutative algebra
  • Learn about the structure of fields and their characteristics
  • Explore examples of commutative rings and identify their ideals
  • Investigate the implications of the Nullstellensatz in algebraic geometry
This discussion is beneficial for mathematicians, algebra students, and educators interested in abstract algebra, particularly those focusing on ring theory and field properties.
Euge
MHB
POTW Director
Here is this week's POTW:
Prove that every commutative ring $A$ with unity in which every proper ideal is prime, is a field.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Hello MHB community,
In case there was any confusion with this problem, unity in a ring is assumed to be nonzero here.
This week's problem was solved by Olinguito, Ackbach, and castor28. You can read Olinguito's solution below.
Let $0\ne x\in A$. We want to show that $x$ has a multiplicative inverse.
First we note that $A$ is an integral domain as the zero ideal $[0]$ is prime (so if $rs\in[0]$ then either $r\in[0]$ or $s\in[0]$). Consider the principal ideal $[x^2]$ generated by $x^2$. If $[x^2]=A$ then $1\in[x^2]$ and so $1=ax^2$ for some $a\in A$ $\implies$ $ax$ is the multiplicative inverse of $x$. Otherwise $[x^2]$ is a prime ideal; then, as $x^2=x\cdot x\in[x^2]$, we have $x\in[x^2]$ $\implies$ $x=bx^2$ for some $b\in A$; hence, as $A$ is an integral domain, $1=bx$ $\implies$ $b$ is the multiplicative inverse of $x$.
So every nonzero element of $A$ has a multiplicative inverse, showing that $A$ is a field. (In this case $[0]$ is the only prime ideal of $A$.)
