Is There a Simple Group of Order $2n$ for Odd $n \geq 3$?
  • Context: Undergrad
  • Thread starter Thread starter Euge
This discussion addresses the proof that no simple group exists of order $2n$ where $n$ is an odd integer greater than or equal to 3. The problem was part of the Problem of the Week (POTW) on Math Help Boards, and was successfully solved by users Olinguito and castor28. Their solutions provide insights into the structure of groups and the implications of group order on simplicity.
  • Understanding of group theory concepts, specifically simple groups.
  • Familiarity with group order and its implications in abstract algebra.
  • Knowledge of the classification of finite groups.
  • Basic proficiency in mathematical proofs and logic.
  • Study the classification of finite simple groups.
  • Explore the implications of group order on group structure.
  • Learn about Sylow theorems and their applications in group theory.
  • Investigate examples of simple groups and their properties.
This discussion is beneficial for mathematicians, particularly those specializing in abstract algebra, students studying group theory, and anyone interested in the properties of simple groups and their classifications.
Euge
MHB
POTW Director
Here is this week's POTW:
Prove that there is no simple group of order $2n$ where $n$ is an odd number $\ge 3$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
This week's problem was solved correctly by Olinguito and castor28. You can read their solutions below.
1. Olinguito's solution.
Let $G$ be a group of order $2n$, $n\ge3$ and odd. Consider $G$ as acting on itself by left multiplication. This gives, for each $g\in G$, a permutation $\varphi_g$ of $G$ where $\varphi_g(x)=gx$ for $x\in G$, and the set of all $\varphi_g$ forms a group isomorphic to a subgroup of the symmetric group $S=S_{2n}$ (and may be considered as the subgroup itself).
Now the mapping $\vartheta:G\to S$ with $\vartheta(g)=\varphi_g$ is a monomorphism (injective homomorphism); therefore $T=\vartheta(G)$ has order $2n$. Any Sylow 2-subgroup of $T$ has order $2$ and so contains an element $\tau$ of order $2$. Furthermore $\varphi_g:G\to G$ has no fixed point unless $g=e$. It follows that $\tau$ is a product of disjoint transpositions (since it has order $2$) and there are $\dfrac{2n}2=n$ of these transpositions (since it has no fixed point); as $n$ is odd, $\tau$ is an odd permutation. Therefore $T\ne A$ where $A$ is the alternating group $A_{2n}$.
As $\dfrac{|S|}{|A|}=2$, $AT=S$. By the second isomorphism theorem,
$$\frac{|T|}{|A\cap T|}\ =\ \frac{|AT|}{|A|}\ =\ \frac{|S|}{|A|}\ =\ 2.$$
It follows that $\vartheta^{-1}(A\cap T)$ is a subgroup of $\vartheta^{-1}(T)=G$ of index $2$ and so is normal. So $G$ has a proper normal subgroup, and as $n>1$ it is not the trivial subgroup. This shows that $G$ is not simple.
2. castor28's solution.
Let $G$ be a group of order $2n$, where $n>1$ is odd. The action of $G$ on itself by left multiplication defines a homomorphism $\varphi:G\to S_G$ such that $\varphi(g).x = gx$ ($S_G$ is the symmetric group on the set $G$).
If $\psi:S_G\to\mathbb{Z}_2$ is the parity map, we have a composite homomorphism:
G\stackrel{\varphi}{\to}S_G\stackrel{\psi}{\to}\mathbb{Z}_2
The kernel $K$ of that homomorphism $\psi\circ\varphi$ is a normal subgroup of $G$. To prove that $G$ is not simple, we must prove that $K$ is neither trivial not equal of $G$, i. e. that $G$ contains elements $a$ and $b$ such that $\varphi(a)$ is odd and $\varphi(b)$ is even.
Let us take $a$ as an element of order $2$, whose existence is guaranteed by Cauchy's theorem. The permutation $\varphi(a)$ only contains transpositions. As this permutation contains no fixed points, there are $n$ transpositions. As $n$ is odd, $\varphi(a)$ is an odd permutation.
We can take $b=c^2$ where $c$ is an element of odd order (since $n$ is divisible by at least one odd prime, the existence of such an element is again guaranteed by Cauchy's theorem). This means that $b\ne1$, and $\varphi(b)=\varphi(c)^2$ is an even permutation.
The conclusion is that $K=\ker(\psi\circ\varphi)$ is a proper non-trivial normal subgroup of $G$, and $G$ is not simple.
